Connecting your AV receiver & speakers to your TV and other devices - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-30-2013, 08:47 AM - Thread Starter
burghman51's Avatar
I am a newbie to this forum and a newbie to home theater systems altogether. What is the best way to setup your AV receiver, speakers and other devices. I only have a Panasonic GT50 TV, blue ray player, directv satellite box, and Wii. I have not purchased a receiver or speakers yet but have been doing some research. I want the setup to be as easy as possible so that i dont have to turn on several remotes just to watch TV (my wife will kill me). I also will not be using the surround sound speakers at all times as i have kids that still take naps and go to bed early. Can i simply plug all my devices into the receivers HDMI in and connect 1 HDMI out to the TV? Do i need an optical cable running from the TV to the receiver? Or is it better to connect all devices to the TV and 1 optical cable to the receiver? I'm assuming i need a receiver with the capability of HDMI pass through so i can watch TV using the TV speakers if i need to. I'm aslo looking for suggestions on receivers and speakers or HTIB. budget is between $400 to $600 for everything. Speaker cable is already ran in my family room when i purchased the house. Thank you.
burghman51 is offline
post #2 of 7 Old 01-30-2013, 08:59 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
You seem to have a good handle on how things work. I'd suggest including a Harmony remote in your set up, which simplifies all the input switching. Very family friendly.
HDMI passthrough should allow you to use the TV speakers. But, CEC can be a bit squirrelly at times.
Run everything through the receiver, not the TV. TVs usually output stereo from HDMI attached devices.
BIslander is offline
post #3 of 7 Old 01-30-2013, 09:34 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yes.
No, HDMI carries both audio and video.
That can cause problems with surround because not all sources can pass multichannel thorugh the TV to something hanging off of it. That's one of the benefits of HDMI to the AVR, it gets the cleanest possible shot at the sound.
Or, just turn on the speakers on the TV!
I'm also looking for suggestions on receivers and speakers or HTIB. budget is between $400 to $600 for everything. Speaker cable is already ran in my family room when i purchased the house. Thank you.
That isn't much of a budget! You might be better off setting up a 2.1 system and leaving the rest for later expansion.
This is the lowest cost receiver that I can possibly recommend:
http://www.accessories4less.com/make-a-store/item/ONKHTRC330/Onkyo-HT-RC330-5.1-CHANNEL-HOME-THEATER-RECEIVER/1.html
Here are some really good but inexpensive speakers:
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32
They would match up well with this inexpensive subwoofer:
http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0
Letsee: $130 + 170 + 190 = $490 plus shipping.
arnyk is offline
post #4 of 7 Old 01-30-2013, 11:06 AM - Thread Starter
burghman51's Avatar
Arny - when i mentioned about HDMI pass through, i am concerned with always having to use the surround sound speakers. If i would like to only use the speakers from the TV and not the surround sound speakers, what is the easiest way to accomplish this?
Second - i found the following receivers and speakers within my budget and all have good reviews. What are your thoughts on these:
Yamaha YHT-497 HTIB - comes with RXV373 receiver. Or purchasse the RXV373 $189 newegg and Polk RM510 speakers which comes with subwoofer.
post #5 of 7 Old 01-30-2013, 11:18 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
HDMI standby passthrough is the recommended way if you simply want to attach your devices to the receiver. Without that feature, the receiver won't pass sound to the TV unless it is powered up. The RXV373 does not have HDMI Standby Passthrough, btw.
The other choice is running a second video and audio connection to the TV from any device you want to watch without using the sound system. You'd run HDMI to the receiver for surround sound viewing and component video with analog stereo audio direct to the TV for listening with the TV speakers. That kind of set up would add to the importance of a good remote. We set up our system that way with an option to use just the TV speakers from the cable box. But, we never use it.
post #6 of 7 Old 01-28-2015, 07:19 AM
Quoted: 18 Post(s)
Liked: 0
can anyone suggest me good HDMI 2.0 cable ?
Taifur is offline
post #7 of 7 Old 01-29-2015, 03:20 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Go to monoprice.com... AVSForum sponsor.
fbov is offline
