Is this a "balanced" setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-30-2013, 03:05 PM - Thread Starter
Konokai's Avatar
What I'm thinking about buying:
Speakers:
Polk Audio TSi200 Bookshelf Speakers - $270
http://www.amazon.com/gp/product/B0018QRO9A/ref=ox_sc_act_title_6?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Receiver:
Onkyo TX-8255 Stereo Receiver - $170
http://www.amazon.com/gp/product/B001AMSPQI/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
Subwoofer:
BIC America F12 12-Inch 475-Watt Front Firing Powered Subwoofer - $190
http://www.amazon.com/gp/product/B0015A8Y5M/ref=gno_cart_title_1
Are any of this items a "bottleneck" for the other items? That is, am I getting a good set of speakers but pairing it with a bad receiver or subwoofer? Is the receiver adequate for my speakers?
I plan on having the speakers sitting around 2-4 feet from me on my desk while using my PC. I don't plan on turning my speakers up too loud since I live in an apartment.
Any help is greatly appreciated!
Konokai is offline
post #2 of 7 Old 01-30-2013, 03:51 PM
Mister Bean's Avatar
The receiver doesn't have LFE out. So you'll have to use the high level inputs on the sub. It may not be a big deal to you, but it's something to be aware of.
Mister Bean is offline
post #3 of 7 Old 01-30-2013, 03:55 PM - Thread Starter
Konokai's Avatar
I was planning on using an RCA Y-adapter connected to an LFE cable to connect the receiver to the subwoofer. Is there some advantage to using the high level inputs instead?
Konokai is offline
post #4 of 7 Old 01-30-2013, 04:04 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Where on the AVR do you intend to plug the cable in?
This one, the Onkyo tx-sr313 has the jack you desire:
arnyk is offline
post #5 of 7 Old 01-31-2013, 09:52 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 151
What mrbean and arny have said is that you have no RCA jack for LFE on this AVR. You do not have the right connections for the AVR to do bass management: set high pass frequency for speakers, low pass for the sub, and integrate all the bass signals into a single LFE channel.
Your only choice is to use the high-level input on the sub, allowing it to do the crossover. This is not the same as 5.1 with an LFE channel as the sub won't alter the signal to the speakers you run through it one bit, and no other speakers are aware there's a sub.
Arny references the Onkyo SR313 which, for the same money, gives you bass management capability on the AVR. Both work, but LFE's better, IMHO.
HAve fun,
Frank
fbov is offline
post #6 of 7 Old 01-31-2013, 03:29 PM - Thread Starter
Konokai's Avatar
For clarification, I was hoping to plug the RCA-Y adapter to the AVR using one of the "out" pairs and then plugging the LFE into the RCA-Y adapter. But I guess that's not possible, my mistake.
Specifically, I was planning on using these cables:
http://www.amazon.com/gp/product/B004EBX5GW/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A1DCPNQKKEISZB
http://www.amazon.com/Mediabridge-Ultra-Series-Subwoofer-Cable/dp/B003FW0WIK/ref=pd_bxgy_misc_text_y
However, the Onkyo tx-sr313 seems to be a better value at the price, so I'm probably going to get that one instead.
Thanks for the feedback, everyone!
Konokai is offline
post #7 of 7 Old 01-31-2013, 04:26 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
You made a good call, because the only RCA outs on the 2 channel receiver seem to be tape outputs, and while they are controlled by the input selector, they are not usually controlled by the volume control.
arnyk is offline
