Center channel/dialog problem. Please help, I'm at my wits end! - AVS Forum | Home Theater Discussions And Reviews
Old 01-31-2013, 08:05 PM - Thread Starter
Brodiego's Avatar
If there's an answer to my question on AVSforum, I can't find it... Many thanks in advance for your help!
My previous setup:
PS3
Projector
Sony HT-SS370 HTIB
I was perfectly satisfied with its performance, but the receiver died.
My new setup:
PS3
Projector
Yamaha RX373 (Sony STR-DH520 returned)
Definitive Tech Prosub 800
The old 3/2 speakers from the old Sony HTIB
When playing Blu-ray movies, the dialogue is tinny/thin/distant, especially if there is music/action going on in the scene. I do not have this problem when the source is either Netflix via PS3 or cable tv signal.
I have tried: adjusting the center channel level; switching the PS3 to bitstream; changing the sound fields, changing the surround modes. Does anyone know how to fix this issue?
I returned the Sony receiver and set up the Yamaha: I'm having the exact same problem!
Brodiego is offline
Old 02-01-2013, 05:40 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
My previous setup:
PS3
Projector
Sony HT-SS370 HTIB
My new setup:
PS3
Projector
If you get the same results with two different AVRs, then we are left with:
"The old 3/2 speakers from the old Sony HTIB"
Room acoustics.
arnyk is offline
Old 02-01-2013, 08:52 AM
Selden Ball's Avatar
Quoted: 3131 Post(s)
Liked: 1538
Have you run the receiver's room equalization software (YPAO)?
That should help balance the outputs of your speakers -- both their volume levels and their frequency responses.
Also, before you run the calibration, make sure the center speaker is oriented so that it points up (or down) toward where your ears are located in your primary listening position. Most tweeters are directional, so if you're off-axis, they don't sound as good as when you're on-axis. If it's in an "entertainment center", make sure that the center speaker protrudes out from it, not set back in the shelf.
Selden
Selden Ball is offline
Old 02-01-2013, 10:54 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
What are your interconnects? (HDMI, optical, digtial coax, etc.)
From what you say, it sound as if the BD player isn't sending a surround data stream. That's either a connectivity issue, or the BD player isn't set up to send the right 5.1 content. Do all the speakers make sound when using BD, just badly? Or are channels missing?
HAv efun,
Frank
fbov is offline
Old 02-01-2013, 02:53 PM
commsysman's Avatar
Quoted: 1005 Post(s)
Liked: 530
The AVR and speakers can't cause this problem IMO.
It seems that it must be an interfacing issue between the PS3 and the receiver.
I think that it might be that you need to use a component-video connection rather than HDMI between the PS3 and receiver.
commsysman is offline
