Possible ways to damage a DAC? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 01-31-2013, 10:46 PM - Thread Starter
Barbarian887's Avatar
So I was curious, how can a DAC become damaged?
(Aside from obvious things like a power surge frying it)
Barbarian887 is offline
post #2 of 19 Old 01-31-2013, 11:12 PM
sdurani's Avatar
Quoted: 5129 Post(s)
Liked: 3608
Pouring water inside it.
Sanjay
sdurani is online now
post #3 of 19 Old 02-01-2013, 02:09 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1242
(1) Plug in the wrong wall wart, a 28 volt one for a printer instead of the 5 volt one that it is supposed to be used with.
(2) Fry the coax input buffer with a massive static charge, near lightening hit, bad grounding problem.
(3) Fry the output buffers using the same methods as (2).
(4) Soak it with Coca Cola or other carbonated, sugared soft drink.
(5) Drop it into sea water while operating.
(6) Drop it off the top of a tall step ladder onto a concrete floor.
(7) Run it over with a fork lift truck
(8) Actually believe an audiophile subjective report about the latest model killobuck DAC - destroys its sound quality as well as (1) - (7)
arnyk is offline
post #4 of 19 Old 02-01-2013, 10:26 AM
pokekevin's Avatar
Quoted: 18 Post(s)
Liked: 102
Playing MP3s thru it
pokekevin is offline
post #5 of 19 Old 02-01-2013, 11:16 AM
bfreedma's Avatar
Liked: 51
EMP pulse from a nuclear detonation.
Seriously though, a DAC is susceptible to the same things that damage electronics in general: Too high an ambient temperature, solder joint failure and all of the multitude of possible but unlikely issues electronics are prone to.
bfreedma is offline
post #6 of 19 Old 02-01-2013, 11:48 AM
filecat13's Avatar
Quoted: 43 Post(s)
Liked: 105
Send it 1s and 2s instead of 1s and 0s.
More seriously, the four big enemies are water, heat, chemicals, and physical impact. The fifth is stupidity.
1. Don't get it wet or keep it in an overly humid environment.
2. Don't overheat it by placing it near or on a source of excessive heat or cut off its access to air circulation.
3. Don't keep it near or expose it to corrosive chemicals and solvents.
4. Don't drop it, hit it, drop something on it, or set a heavy weight on it.
5. Dont take it apart, don't stick things through the air holes, don't drop candle wax in it, don't spray it with cleaners, don't dump sand in it, don't put peanut butter on it, don't twirl it by its power cord, IOW, don't be stupid.
Yes, it's also possible to fry it electrically, but most scenarios involving electricity would also fall into the don't be stupid category, and it really doesn't happen too often.
What I can afford, when I can afford it...
filecat13 is online now
post #7 of 19 Old 02-01-2013, 12:02 PM - Thread Starter
compressed audio can damage it??
I don't know if you're joking or not because I don't know about that...
post #8 of 19 Old 02-01-2013, 03:56 PM
edoggrc51's Avatar
Quoted: 70 Post(s)
Liked: 86
Only if its a 64kbps file.
edoggrc51 is offline
post #9 of 19 Old 02-01-2013, 03:57 PM
Brad Horstkotte's Avatar
Liked: 73
Oh come on, stop perpetuating these audiofool myths Doug
Brad Horstkotte is offline
post #10 of 19 Old 02-01-2013, 04:14 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5035
Not quite that! Even iTunes mp3's can harm a DAC. I've fried two already with albums downloaded from Apple.
Scott Simonian is offline
post #11 of 19 Old 02-01-2013, 04:19 PM - Thread Starter
How does that work?
post #12 of 19 Old 02-01-2013, 04:44 PM - Thread Starter
What?
This doesn't make any sense to me, just, what?
explain how this works
post #13 of 19 Old 02-01-2013, 04:48 PM
IwantmyTHX's Avatar
I once ruined one by hooking it up to the USB out on my Audio-Technica AT-LP240-USB Turntable!
IwantmyTHX is offline
post #14 of 19 Old 02-01-2013, 04:49 PM
edoggrc51's Avatar
Quoted: 70 Post(s)
Liked: 86
How does that work?
At that bit rate the file is much too compressed. So much so that it can spontaneously combust inside the DAC.
Did they happen to be Justin Bieber records?? I heard those were SUPER compressed and very dangerous.
post #15 of 19 Old 02-01-2013, 04:54 PM - Thread Starter
is this real life?
post #16 of 19 Old 02-01-2013, 05:21 PM
Will2007's Avatar
Quoted: 14 Post(s)
Liked: 136
is this real life?
No, this is just fantasy.
Will2007 is offline
post #17 of 19 Old 02-01-2013, 05:22 PM - Thread Starter
Well at least it isn't caught in a landslide, is it?
post #18 of 19 Old 02-01-2013, 05:28 PM
holt7153's Avatar
Quoted: 139 Post(s)
Liked: 221
Absolutely, much like people dozens of DACs spontaneously combust each year. It's just not really widely reported.
Anything good in life is either illegal, immoral, or fattening.
holt7153 is online now
post #19 of 19 Old 02-01-2013, 05:35 PM
filecat13's Avatar
Quoted: 43 Post(s)
Liked: 105
Well, how do you like them fried apples? Baked with brown sugar and cinnamon?
It's said that every time a DAC fries, an apple gets it wings.
