7.1 Speaker Placement in Long Room - AVS Forum | Home Theater Discussions And Reviews
Old 02-03-2013, 10:32 AM - Thread Starter
Jake45's Avatar
This has probably been posted and answered a 1000 times, but I'm not finding a specific answer to my speaker placement conundrum. I have a great room style home, with my home theater setup in one end of the room. The entire room is about 14 ft. wide and 55 ft. long. Front speakers are setup in normal "Dolby" fashion, but wall arrangement prevents a perfect rear and side surround setup. The main listening position is about 13-14 ft. from the HDTV/ center speaker, which is centered on the 14 ft width of the wall. Currently, I have a 5.1 set up with in-wall speakers for the rears. They are placed about 7 feet high, and are about 6 ft. behind the listener. I want to go 7.1, so I need to add the side surrounds. The only place I can really place them is at the 7 ft. high level, but they would be about 3-4 ft. in front of the listening position. My question is if having the side surrounds slightly in front of the listening position will obtain less than optimium results in 7.1? Doing a simple angle measurement, the side surrounds would be at about a 75 degree positon (opposed to the recommended 90-110 degrees), and the rears are at about 120 degrees. My thinking is this probably OK, but I don't really want to spend a bunch more money and not feel like I really improved anything. any advise is appreciated.
Jake45 is offline
Old 02-03-2013, 01:41 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Don't waste your time or money. Leave it as a 5.1. I've had 7.1 in the past, its only slightly better 90% of the time.
And I had perfect placement of all 4 surrounds.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
4DHD is offline
Old 02-03-2013, 02:09 PM
asarose247's Avatar
Quoted: 701 Post(s)
Liked: 457
my room is not as long but given your width and MLP preference, and other parameters ,I solved my rear and side mounting like this;
I penciled the problem a while and got this: 2 eight foot track light bars, one end anchored to the walls and then in a dihedral sorta angle to give the possibility of equidistant surrounds and rears (from MLP). I searched around for track light fixtures (USED isok, its the hangers thatr need to be ok) and " removed " and reconfigured the susupension part that fits into the bar (you'll need to extract most of the innerards and keep a sectiion of the rubber isolator to provide proper retention). So then i fabricated an appropriate rube goldberg to give me a good attachment for the speakers. I had to beef up some attachement points to retain swivel and angulation possibilities. I ran the wires thru the ceiling ( my home-my way). I painted the rack light bar and the hangers light primer grey. I used a plate and 2 each toggle bolts to hold the central ends , separately .
My surrounds are Klipsch RS3S and the rears are Klipsch SLX. The rears hand down about 15 inches from the ceiling but i "stretched" the hanger for the surrounds and have them down in the range normally suggested to height and angle WRT listening level at the MLP.they are very close to the wall so the extra "hang" is not a problem.
there seems to be an issue with with attaching the photo but i'm willing to address the porblem, just right not today, it "super sunday" duh!
DIY FAN Denon X5200 , ATI A 2000 for 7.4.6 SCATMOS/DSU/SHARP 80" LED/LCD
L/R: Fusion 15 V2 , C: 88 Special , SL/SR: F4Q4LP , RL/RR: F-3, TF/TR: Volt 6's TM: SLX
SUBMAXIMUS, ,Submaximus V3,LOWARHORNCustom Dual Driver VBSS,2 x Inuke6000DSP
www.avsforum.com/forum/155-diy-speakers-subs/1485120-submaximus-large-front-loaded-horn
http://www.avsforum.com/forum/155-di...orn-build.html
asarose247 is online now
Old 02-04-2013, 08:57 AM
sdurani's Avatar
Quoted: 4506 Post(s)
Liked: 2911
Can you move your seating 1-2 ft. forward? This will kill 2 birds with one stone: make the Rear speakers further behind you AND get the Side speakers closer to your sides (it's OK to have them slightly forward of the listening position). Should give you better wrap-around envelopment and excellent rear-vs-side separation in the surround field.
Sanjay
sdurani is online now
