In wall speaker placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-04-2013, 02:56 PM - Thread Starter
drewwfulkerson's Avatar
I am interested in using three R-3800-W II In-Wall Speakers for my front, center, and left in my new home theater, but I am unsure of placement on these speakers. The room is a finished space over my garage, so the space has sloped ceilings. The wall they will be mounted in is an odd shape (hexagon)due to the sloped ceilings. The floor measurement is 10'6", the knee wall is 5', the slope is 4'8" at 49.6 degrees, and the flat part of the ceiling is 3'5". My TV is 50", but I plan on getting a larger one in the future. Can you please give me advice as to where to mount these speakers?
drewwfulkerson is offline
post #2 of 7 Old 02-04-2013, 10:34 PM
commsysman's Avatar
Quoted: 963 Post(s)
Liked: 521
At a given price point, the sound quality of in-wall speakers is far inferior to that of speakers that have their own enclosure with a correct acoustic design. Holes in walls do not make a good speaker enclosure.
If you must put speakers in your walls or ceiling, do so with the knowledge that you are not going to achieve particularly good sound quality and will pay through the nose for what you do get.
Of course, you CAN get cheap public-address-quality speakers to stick in a wall, but the ones that sound halfway decent are very expensive!
I wouldn't wish in-wall speakers on my worst enemy; even the very best of them.
Rasta Linus likes this.
commsysman is offline
post #3 of 7 Old 02-05-2013, 12:31 AM
pokekevin's Avatar
Liked: 102
A properly designed In-wall can sound just as good, and possibly even better, than its in room counterpart.
pokekevin is offline
post #4 of 7 Old 02-05-2013, 06:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
There are several big potential advantages to an in-wall installation done right:
(1) Flush mounting the drivers with the wall avoids speaker cabinet diffraction problems.
(2) Putting the speaker in the wall avoids peaks and dips due to reflections off the wall behind the speaker
I wouldn't be surprised if it evolved that some people are reacting badly to the removal of these potentially audible artifacts.
I'm thinking of the very real backlash against digital because it removed the audible artifacts of vinyl.
Of course the dog in the stable is this business of properly designing the in-wall system. It probably isn't done a lot.
arnyk is offline
post #5 of 7 Old 02-05-2013, 07:09 AM
Tyler Leary's Avatar
I think the point here was "at a given price point." I'm curious how much of a premium someone might pay per front speaker to get equivalent sound quality. For instance a dealer bid me SpeakerCraft-AIM CINEMA ONE in-wall LCRs, but I have no idea what floorstanding/bookshelf-type speaker that might be equivalent to in terms of performance.
Tyler Leary is offline
post #6 of 7 Old 02-05-2013, 07:18 AM
Skytrooper's Avatar
Quoted: 221 Post(s)
Liked: 144
Thought I'd post some pics of my in wall speakers. I like in wall because I don't want the room to look like speakers everywhere. As you can see, I built enclosures to enhance their performance. 2 X 6 side walls for the surrounds, 2 X 4 rear walls for the surround backs. As I was working on the addition, I connected a old 2 channel Akai Receiver to the left and right surrounds. They played very loud and sounded terrific. Don't let anyone discourage you about in walls. My 7.1 system rocks.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #7 of 7 Old 02-06-2013, 11:44 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
There are some very good in-wall designs out there...
http://www.htguide.com/forum/showthread.php4?t=32111
And no one's mentioned that the lack of BSC means they're 3-6dB more sensitive.
The units you mention are Klipsch, which may stir opinions, but definitely are not one of the cheap, generic, low-quality ceiling speakers - and they are available - which deserve commsysman's comments.
Have fun,
frank
fbov is offline
In Wall Speakers
