New home with terminal plates high up on wall...? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 02-07-2013, 06:22 PM - Thread Starter
jungiandreams's Avatar
I believe they are speaker terminals, a thin orange line on one gold connector, a red line on the other. Anyone have any ideas...? How would you utilize them in your home theater? Your receiver is down near ground level, why are the speakers 15 feet in the air? There are five sets in each room. Could it be something other than speakers...?
jungiandreams is offline
post #2 of 13 Old 02-07-2013, 07:50 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1239
Picture?
arnyk is offline
post #3 of 13 Old 02-07-2013, 08:08 PM - Thread Starter
Will post pic as soon as I get one. They look like wall plate with two gold connectors for banana plugs, so I assume they are speakers. But, there is no main plate that you can connect to a receiver. So what the heck are all these prewired plates wired to...?
post #4 of 13 Old 02-08-2013, 07:52 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 698
how about asking the prior owner/real estate agent also.....
mtbdudex is online now
post #5 of 13 Old 02-08-2013, 08:52 AM - Thread Starter
the previous owner said it is wired for speakers. there was no discussion beyond that. i guess that was not the priority at the time. is it normal to wire speakers just shy of the ceiling, and in adjacent rooms?
post #6 of 13 Old 02-08-2013, 08:54 AM
JD in NJ's Avatar
Liked: 36
Whatever normal is doesn't really matter, the question is whether or not you intend to try using them as is.
If so, there's bound to be another end to each cable somewhere in the house, most likely all concentrated in one closet or something.
JD in NJ is offline
post #7 of 13 Old 02-08-2013, 09:07 AM - Thread Starter
so a-hunting i will go. huge house. the connections do not end up at the opposite wall to what I thought to be the rear speaker terminals in each room. So it stands to reason there will be a main plate with connections for a receiver for speakers a and b.
post #8 of 13 Old 02-09-2013, 10:21 AM
commsysman's Avatar
Quoted: 987 Post(s)
Liked: 526
Time to get out an ohmmeter and some very long test lead wires to find what goes to what.
The obvious reason that occurs to me for having the plates up high is that that is where the rear or surround speakers were mounted to the wall; up high.
commsysman is offline
post #9 of 13 Old 02-09-2013, 06:55 PM - Thread Starter
all of the plates are up at ceiling level. seems strange to me, to have them up so high. wouldn't that compromise the integrity of the sound?
post #10 of 13 Old 02-09-2013, 08:19 PM
A9X-308's Avatar
Quoted: 1331 Post(s)
Liked: 1003
You only need a short wire (and an assistant to make the process quicker). Short one pair at the destination end and use the DVM to determine which pair it is. Mark the cable and repaet for all the others.
They probably weren't interested in fidelity, probably background sound and/or having the speakers out of the way.
A9X-308 is offline
post #11 of 13 Old 02-10-2013, 09:12 AM
Overtone's Avatar
They were probably for wall or ceiling mounted speakers similar to what you see at restaurants. There must be a terminal or closet somewhere for the source signal to feed into the system.
Overtone is offline
post #12 of 13 Old 02-10-2013, 09:34 AM
krakhen's Avatar
Maybe just a sound/music distribution system? Good luck with your hunt!
__________
Krakhen
krakhen is offline
post #13 of 13 Old 02-11-2013, 08:25 AM - Thread Starter
Thanks for the luck. They've had no luck locating the main plate. And, even worse, the speakers are in the two rooms flanking where they'll actually want the surround sound system. I am envisioning a main plate with connections for two sets of speakers (speaker a and b). So we'll have to move one set of wires into the center room. This is not going to be easy. It may just be easier to forget the in-wall connections and set up a traditional surround sound running new wire. Lame.
