Should I set my front towers to large? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-08-2013, 02:54 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
I was assuming that setting my front speakers to large is the best choise because the woofers on my fronts are 10'' and my subwoofer is only 8'' (jamo sub250).
Should i set my fronts to large , and the other speakers to small with 80 x-over?
dazkyl is offline
post #2 of 17 Old 02-08-2013, 03:03 PM
JD in NJ's Avatar
Liked: 37
Large = "Don't send any bass to subwoofer from this speaker"
Small = "Send any bass below this speaker's crossover point to the sub"
JD in NJ is offline
post #3 of 17 Old 02-08-2013, 03:07 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
I know what they mean , but THX and also many people recommend everything to small with a crossover of 80hz. I was thinking of setting my fronts to LARGE for the reason that the woofer is bigger then the driver of my subwoofer. 10'' vs 8''. Maybe i will get a stronger ''bass'' from my fronts. Unfortunately,my avr only let me choose a crossover for all the speakers.
dazkyl is offline
post #4 of 17 Old 02-08-2013, 03:10 PM
JD in NJ's Avatar
Liked: 37
This gets to be a reasonably complicated issue, and there are many discussions about it here which go into all the depth you probably want. I just wanted to make sure it's clear that "large/small" don't mean big and little when it comes to bass management.
JD in NJ is offline
post #5 of 17 Old 02-08-2013, 05:58 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
The mains are placed for proper imaging, which is likely not the best placement for bass response. The sub can be placed wherever it takes to maximize bass performance. So, even if your mains are capable of handling deep bass, setting them to small and using the sub may still work better.
BIslander is offline
post #6 of 17 Old 02-08-2013, 09:20 PM
eljaycanuck's Avatar
Quoted: 1344 Post(s)
Liked: 1959
eljaycanuck is offline
post #7 of 17 Old 02-09-2013, 05:13 AM
mogorf's Avatar
Quoted: 1117 Post(s)
Liked: 714
Set your speakers to Small and do a subwoofer crawl. Let the sub handle the deep bass even if it's only 8" it's power handling capability will ensure you what it was designed for.
mogorf is online now
post #8 of 17 Old 02-09-2013, 05:21 AM
Theresa's Avatar
Liked: 51
I would get a bigger sub, at least 12" in a >3cf cabinet. Size of the enclosure does matter, the smaller the enclosure the less bass you'll get without EQ. Some subs, such as the Emotiva one's, trade off deep bass for a small enclosure <2cf. Because you're sub is so small that it may be less capable than your mains each of which has a 10" woofer, compared to a single 8" in your sub.
Theresa is offline
post #9 of 17 Old 02-09-2013, 07:21 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Try both and see what sounds best to you.
I see your point, we are trading off a single 8" moderate xMax driver against two 10" drivers that probably have less xMax but we don't know for sure. The sub isn't wasted because it is still probably doing LFE duty.
I like Theresa's idea - get a decent Sub. It is too bad you aren't in the states and capitalize on things like Amazon's < $200 deal on Polk PSW 505s.
arnyk is offline
post #10 of 17 Old 02-09-2013, 02:41 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Indeed. Im sticking with fronts to large and others to small with 80 x-over. Will getting another sub to have two is a good idea? I was thinking of adding a 12'' along with my 8''.
dazkyl is offline
post #11 of 17 Old 02-09-2013, 07:35 PM
Espo77's Avatar
Quoted: 182 Post(s)
Liked: 85
I know that you have posted here before, but I can't remember what the make and model of your front speakers are. Can you please state the make and model?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #12 of 17 Old 02-10-2013, 02:29 AM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Theyre the jamo s608 tower speakers. I find bass is much more dynamic when fronts are set to large. It maybe be because my sub is a 8'' comapred to my fronts which both have a 10'' woofer or maybe because the sub placement. I got lack of space in the room , so i put my sub in the front left corner, and when i turn the knob volume past , say , 10 o'clock , it starts to rumble during action movies. I have to leave it at 9 o'clock so it wont rumble , but i will have a lot less bass.
dazkyl is offline
post #13 of 17 Old 02-10-2013, 02:56 AM
mogorf's Avatar
Liked: 714
What AVR do you have? Does it have an auto-calibration system? Did you run it?
post #14 of 17 Old 02-10-2013, 12:38 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Its the onkyo tx sr308. It does not have any auto calib setups
dazkyl is offline
post #15 of 17 Old 02-10-2013, 01:05 PM
mogorf's Avatar
Liked: 714
I see. Well, in that case you will still need to setup your system as outlined in the Manual of the Onkyo TX-SR308 starting from page 30. (Just looked it up for you!) The two most important things you need to do are:
1. Speaker distance setting. You will need measuring tape to enter the values manually.
2. Speaker level setting. You will need to buy/borrow a sound level meter and use the built-in test tones to calibrate your speakers' levels.
When done you can set the global crossover to 80 Hz and listen. And if you like it you can call it a day. If not, come back for more assistance. smile.gif
post #16 of 17 Old 02-11-2013, 10:51 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 771
mogorf is spot on with advice, i would add if you have a smart phone try a free spl app if you can't borrow one, no need to spend $40 ish for one time use.
It will get you very close to a dedicated meter, and more important you will have same relative spl from each channel then at your MLP, master listening position.
Sent from my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #17 of 17 Old 02-13-2013, 09:36 AM
Larry L's Avatar
Isn't the mic on a smart phone very directional? Would laying it on its back give a good pattren?
Larry L is offline
