Bitstream (mix) works but Linear PCM doesn't... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-09-2013, 10:42 AM - Thread Starter
musicisgreat108's Avatar
I have an old 1970s Pioneer Reciever that is in perfect shape and produces amazing sound. Since it doesn't have any digital inputs I purchased a digital to analog converter that runs from my PS3 through an optical digital cable then to R/W RCA to the reciever. When watching a movie through DTS MA HD the low bass ends are extremely crackly. I had it switched to Linear PCM output because I figured my reciever wouldn't be able to decode the DTS. But then I switched it to Bitstream (mix) and it worked. Low bass ends and all.
So am I getting the best out of my sound or no?
musicisgreat108 is offline
post #2 of 5 Old 02-09-2013, 10:45 AM
commsysman's Avatar
Quoted: 970 Post(s)
Liked: 523
You say you switched IT to bitstream and it worked.
WHAT did you switch to bitstream?
More details are needed to make this comprehensible.
commsysman is offline
post #3 of 5 Old 02-09-2013, 12:53 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Looks like you are getting the best possible result. with that setup. All you'll ever get is stereo. Bitstream (mix) will be a high bitrate lossy encode. Excellent quality. You can try outputting stereo PCM from the dts-MA track, which might be slightly higher quality.
BIslander is offline
post #4 of 5 Old 02-09-2013, 01:16 PM - Thread Starter
post #5 of 5 Old 02-09-2013, 01:17 PM - Thread Starter
Originally Posted by musicisgreat108 View Post
IT would be the audio output coming out of the PS3 through a optical digital cable converted to R/W RCA cables into my receiver. Sorry I didn't make this clear. Hope this will specify...
