Yamaha HTR 5890 - Set Menu from front panel - AVS Forum | Home Theater Discussions And Reviews
Old 02-14-2013, 03:00 PM - Thread Starter
MusicLuv's Avatar
I recently got a used HTR 5890 without remote control. I need to get to the 'Set Menu' which I believe is available on the remote control. Is it possible to operate the 'Set Menu' from the front panel? Thanks.
MusicLuv is offline
Old 02-14-2013, 03:21 PM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 522
You should be able to down load the manual if you search for it online, and save it or print it.
You would find the remote much more convenient, however. I would contact Yamaha tech support and see if you can get one.
commsysman is offline
Old 02-14-2013, 05:17 PM - Thread Starter
MusicLuv's Avatar
I down loaded the manual and read it. It only mentions using the remote control to operate the Set Menu. I hope somebody knows how to do it from the front panel.
MusicLuv is offline
