What connector is this ? driving me nuts... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 02-16-2013, 01:42 PM - Thread Starter
vinayarora's Avatar
Getting this new house and it is pre wired - however i have never seen connectors like these... can anybody please help me.. thanks
These seem to be audio cables and have the tags on them like bedroom , back yard and all .. the speakers are AR and they are all installed throughout the house.. including surround sound 5 channel....
vinayarora is offline
post #2 of 10 Old 02-16-2013, 02:23 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
Kinda looks like something I've seen on a connector for a trailer hitch. I started googling around and kinda looks like some obsolete molex connectors I found. http://www.molex.com/molex/products/datasheet.jsp?part=active/0512400605_TERMINAL_BLOCKS.xml
lovinthehd is offline
post #3 of 10 Old 02-16-2013, 02:52 PM
SAM64 is offline
post #4 of 10 Old 02-16-2013, 03:15 PM
Dropkick Murphy's Avatar
Quoted: 72 Post(s)
Liked: 89
If you don't have the amp or speaker switch that goes with those connectors just cut them off and use the wires to connect to whatever equipment you want to use. Typical wiring scheme for those 4-conductor wires is:
RED = Right +
BLACK = Right -
WHITE = Left +
GREEN = Left -
You may want to pull apart a volume control and double check.
Dropkick Murphy is offline
post #5 of 10 Old 02-16-2013, 03:22 PM - Thread Starter
vinayarora's Avatar
@dropkick - thanks.. will do that.
post #6 of 10 Old 02-16-2013, 03:23 PM - Thread Starter
vinayarora's Avatar
@SAM64 wow - what equipment/amplifiers use these kind of boards ? thanks
post #7 of 10 Old 02-16-2013, 03:54 PM
Skytrooper's Avatar
Quoted: 225 Post(s)
Liked: 146
Those connectors are designed to plug into something else. I used to use them on 2 way radio controlling devices. You obviously have no use for them, just ditch them. ( I used to like them for what I used to do, retired now. )
vinayarora likes this.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #8 of 10 Old 02-16-2013, 07:21 PM
Glimmie's Avatar
Quoted: 764 Post(s)
Liked: 638
You can get them at:
Www.digikey.com
They will sell directly to consumers.
Glimmie is offline
post #9 of 10 Old 02-17-2013, 09:25 AM
50BMG's Avatar
I'm thinking Alarm System.
50BMG is offline
post #10 of 10 Old 02-18-2013, 07:11 AM
SAM64's Avatar
Liked: 78
Crestron use those connectors as well....many equipment venders do.
SAM64 is offline
