making stereo input output to center and front speakers - AVS Forum | Home Theater Discussions And Reviews
Old 02-20-2013, 10:52 AM - Thread Starter
videopotus's Avatar
All,
Is there a way to make stereo input (such as from broadcast tv) output to my center channel speaker as well as my front speakers? My feeling is that since I bought a center speaker, I want sound to come out of it.
I have a Denon 1613 and an Oppo BDP-103. The cable input runs through both so settings on either would work.
I see in the manual for the Oppo about the settings for down converting 7.1 to 5.1 or 5.1 to stereo, but nothing about up converting--if that is even possible, or advised, Did I miss something in the manual? Is this a bad idea to even want this?
I've also explored the Denon settings, but no dice.
Any help would be appreciated.
videopotus is offline
Old 02-20-2013, 11:45 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Well, you run the tv audio out into the Denon. Then connect the L/C/R output from the Denon to the three speakers.
You then set the Denon output to Dolby PLii, or dts-neo6, which will convert stereo input to muti-channel output.
You will need to setup the speaker menu in the Denon so it knows you have LCRs.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 02-20-2013, 12:06 PM - Thread Starter
videopotus's Avatar
Hmmm. I thought I did that.
Old 02-20-2013, 12:28 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
If its not working, then you need to re-check all the settings in the AVR.
4DHD is offline
Old 02-21-2013, 12:14 PM - Thread Starter
videopotus's Avatar
Did a reboot of the Denon. Now it is working and displaying PL IIc.
