Distance of 7.1 back surrounds? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-24-2013, 07:59 PM - Thread Starter
Jeremy Wadian's Avatar
Quoted: 60 Post(s)
How far away should my back surrounds be from my listening position? Not the height but the distance. Thanks
Jeremy Wadian is offline
post #2 of 9 Old 02-24-2013, 08:39 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
lovinthehd is offline
post #3 of 9 Old 02-24-2013, 09:37 PM - Thread Starter
Quoted: 60 Post(s)
How many feet behind your couch do the rest of you have your 7.1 back surround speakers?
post #4 of 9 Old 02-24-2013, 10:08 PM
sdurani's Avatar
Quoted: 4476 Post(s)
Liked: 2896
There is no recommended distance, just recommended angles (at least ±30° from the centre line, meaning at least 60° apart).
Sanjay
sdurani is offline
post #5 of 9 Old 02-24-2013, 10:52 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
I wouldn't even use rear speakers unless I had at least 4' feet between my ears and speakers.
Jim McC is offline
post #6 of 9 Old 02-25-2013, 04:29 AM
Skylinestar's Avatar
Quoted: 1044 Post(s)
Liked: 182
How much space do you have?
I have 10 feet behind my couch.
Skylinestar is online now
post #7 of 9 Old 02-25-2013, 08:32 PM
lovinthehd's Avatar
Liked: 4775
My rear surrounds are up at top of wall at ceiling junction (but cathedral ceilings), about 6 ft at closest point to the main listening position on the couch (big l-shaped job at an angle), but the right surround at the far right end of the couch is about the same distance, otherwise other positions on the couch are further.
post #8 of 9 Old 05-29-2013, 08:06 AM
Liked: 182
I have a small room of 10x11 feet. I'm planning to fit in a 7.1 setup in it. The rear speakers will be 2.5 feet behind the main listening position. Is that too close?
post #9 of 9 Old 05-29-2013, 03:45 PM
sl1ac's Avatar
I have my rear speakers at 2.5' behind the listening position and sounds okay in my system. Properly set distances and trim levels in the receiver are key for placing speaker in that short of a distance. Ultimately it will be up to you if you like them that close. If you plan on using automatic speaker setup or room correction, such as Audyssey, I've found that the software tends not to like the rear speakers that close to the setup mic. I suggest either doing 1) manual distance and level calibration or 2) skipping the measurements that are made behind the listening position with the automatic setup.
sl1ac is offline
