Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 02-28-2013, 11:34 AM - Thread Starter
Jutl's Avatar
I just purchased Martin Logan Motion 4's as my fronts, 2's as my surround and 6 as my center. Also have a powered Martin Logan 500 subwoofer. I have a Yamaha receiver that is a few years old, but puts out 90watts per channel and can be put at 6phms to match the speakers. I like the sound, but feel I'm not getting everything out of the system. The components are run through HDMI cable and the speakers through good to decent wire. I guess my question is what can I do to improve the overall performance? I just don't feel I'm getting the overall "big" sound I want. Still seems small not wrapping the listner in music.
Also, my cd player just took a dump. I'm using a Blue Ray player knkow to play my cd's. Is this a mistake? Does a good Cd player really make much of a difference?
Thanks for any suggestions.
Jutl is offline
post #2 of 3 Old 02-28-2013, 01:07 PM
mogorf's Avatar
Quoted: 1101 Post(s)
Liked: 675
First question: did you run YPAO on the Yamaha?
Second question: How are your speakers set up in your room? Instead of answering you may post a couple of photos of your setup. Pictures are sometimes worth more than a 1,000 words, eh? smile.gif
mogorf is offline
post #3 of 3 Old 03-04-2013, 06:15 AM - Thread Starter
Jutl's Avatar
I post some photos. Yes I ran the YPAO. I just moved into the new place. My front speakers are sitting on the component stand, but will be placed on speaker stands. The center is mounted on the wall just under the mounted tv. The sub is off to the right of the component stand. The surrounds will be mounted behind the sofa approximately six feet apart. This brings up another question. Do I mount the on the wall just above ear level or as I had them before on the ceiling.
Jutl is offline
