budget friendly set up? (total newbie) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-01-2013, 02:23 PM - Thread Starter
jesseleeroy's Avatar
Hey guys,
Totally new to this sound stuff, been playing music for awhile but don't know much about the whole technical.
So I want to know where i should start off? I dont want to go crazy, thus budget friendly (~$300-400) for my computer, to listen to CD's or MP3's. I read a little about the preamp and DAC but theory and you guys' exp are totally different. So i come here!
I currently have Bose Companion 3, given to me used by an old friend, which I thought was a rip off for the price. (but it was free so i used it til now) I am wondering if there is something clearly better for lower price and something more upgrade-able? i dont grow a dollar tree so lower the better. smile.gif
I usually listen to jazz, musical, bit of acoustics.
Any suggestions please!
jesseleeroy is offline
post #2 of 5 Old 03-01-2013, 02:48 PM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
All you need—and on your budget, all you can afford—are two speakers and some way to amplify them. So you have two ways to go. One is powered speakers,which contain their own amps. Audioengine is a popular brand. Others will no doubt be suggested.
Alternatively, you can get a stereo receiver and a pair of passive speakers (i.e., speakers without amps, which are far more common than powered ones). Keep the receiver budget to a minimum. Sherwood makes models available in the $100 range. For speakers, I like the Infinity Primus series—the largest bookshelf model they make would be a good choice.
When you're ready to move up, the first thing you'll want to do is replace the Sherwood with an AV receiver and add a good subwoofer.
I presume your computer has a sound card with an analog output, so you probably don't need a DAC. If you discover that this is rather noisy you might try a cheap USB DAC. Behringer makes a good one for well under $50.
If you can't explain how it works, you can't say it doesn't.—The High-End Creed
mcnarus is offline
post #3 of 5 Old 03-04-2013, 06:34 AM - Thread Starter
I guess the powered speakers way is more affordable and simpler solution, but without much to upgrade?
post #4 of 5 Old 03-04-2013, 08:20 AM
mcnarus's Avatar
Quoted: 153 Post(s)
Liked: 373
Not necessarily. Powered speakers will be more expensive than passive speakers, because of the built-in amplification. The Sherwood/Infinity set-up I suggested will run you $270. AudioEngine powered speakers run $200-400. Separates give you more flexibility when it comes time to upgrading. Powered speakers are a good choice if space is at a premium.
mcnarus is offline
post #5 of 5 Old 03-04-2013, 03:40 PM
GregLee's Avatar
Quoted: 845 Post(s)
Liked: 287
I wouldn't get powered speakers. A typical hi-fi system has a receiver, sub (powered), and passive speakers. The Sherwood/Infinity combo just suggested sounds good (though I haven't actually had those brands). But don't don't forget used stuff, especially for speakers, since they don't usually break and people discard perfectly good stuff. Not often premium, but good. Once you've got a receiver, you can get speakers for a song from used stores, yard sales, or by Craigslist. Well, so long as you're not picky about the appearances of the speakers.
For receivers, I like Pioneer (have had 4 of them).
Greg Lee
GregLee is offline
