Arduino Instrument - Speaker Connection Dilemma - AVS Forum | Home Theater Discussions And Reviews
Old 03-01-2013, 05:58 PM - Thread Starter
Nathan Klein's Avatar
As a newbie when it comes to circuits and speakers, I'm struggling with a project I've set up for myself.
I'm trying to build a musical instrument out of an Arduino, and I need a speaker for the audio output. I ordered this one off amazon: http://www.amazon.com/gp/product/B008BWA2BQ/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
I know it's cheap, audio quality isn't remotely a priority here. I needed something that was roughly the size and outside appearance that I was looking for.
When it arrived, I noticed it runs from two pairs of speaker cable connections, and I have absolutely no idea how to hook that up to an arduino board. As I said, I'm pretty new to this stuff, so I'm probably saying really dumb things. Regardless, here's how I was thinking of approaching it.
I know how to connect a 3.5mm mp3 jack to the arduino board, so I was going to connect a 3.5mm to stereo rca cable to that, with the rca ends cut off and the wires threaded into the speaker. Is there a better way? Am I missing something? Am I completely wrong? Help!
Nathan Klein is offline
Old 03-01-2013, 06:38 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Nathan,
Originally Posted by Nathan Klein View Post
. . . Am I missing something?
You may be missing something - an amp. I've used a couple of different Arduino boards (not by choice), but none of them had an audio amplifier. Can you post a link to the Arduino board you are trying to use? In lieu of an amp, you could get a powered speaker.
By the way, that speaker you linked to is designed for stereo in a single package - it is actually two sets of speakers, which explains the two sets of wires.
MarkHotchkiss is offline
Old 03-01-2013, 07:19 PM
A9X-308's Avatar
Quoted: 907 Post(s)
Liked: 636
You need an amp. I use a lot of Mega 2560 boards in projects.
A9X-308 is offline
Old 03-01-2013, 07:28 PM - Thread Starter
Of course, I can't believe I didn't think of that. No, I'm sure the arduino uno doesn't have an amp on board, but getting an amp integrated into the build I'm making won't work too well- it has to fit in a specific, rather small space. A powered speaker would work perfectly, if it ran off batteries- but It needs to be roughly the same size and shape as the speaker above (though smaller is better). Do you know of anything like that? Hopefully not too expensive, either (again, there's no need for good quality. It'll be playing sine waves.)
taboola here
