Speaker set up. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 33 Old 03-06-2013, 12:06 AM - Thread Starter
mawnkey's Avatar
I will be purchasing a Yamaha v373 reciever soon and some speakers and will need help setting it up. For now my question is what type of wires should I use for my system? Gauge? Brand? I'm new to this and any and all help would be appreciated
mawnkey is offline
post #2 of 33 Old 03-06-2013, 05:56 AM
baniels's Avatar
Quoted: 210 Post(s)
Liked: 318
baniels is online now
post #3 of 33 Old 03-06-2013, 07:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Speaker cables or interconnects?
Cable lengths?
For speaker cable, the "one size fits all" solution is 12 or 14 gauge wire such as these:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023902&p_id=2820&seq=1&format=2
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10239&cs_id=1023901&p_id=2817&seq=1&format=2
arnyk is offline
post #4 of 33 Old 03-06-2013, 09:17 AM - Thread Starter
mawnkey's Avatar
I'm not sure what interconnects are. The lengths are to be determined, but how much better would the 12 gauge be than the 14?
mawnkey is offline
post #5 of 33 Old 03-06-2013, 09:59 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Cables with RCA connectors on each end. For example:
Depends on the length, but never too much.
arnyk is offline
post #6 of 33 Old 03-06-2013, 10:56 AM - Thread Starter
mawnkey's Avatar
The lengths would be no longer than 25ft
mawnkey is offline
post #7 of 33 Old 03-06-2013, 04:04 PM - Thread Starter
mawnkey's Avatar
How would the speaker wire from say Walmart handle the speakers? It would be 14 gauge?
mawnkey is offline
post #8 of 33 Old 03-06-2013, 06:41 PM
baniels's Avatar
Quoted: 210 Post(s)
Liked: 318
It should list the gauge. It could be 14, maybe 16. Either of which would be fine for at 25 or more ft as long as your speakers are 4ohm or higher - which is extremely likely. Take a peek at the first link I gave you above)
post #9 of 33 Old 03-06-2013, 06:44 PM
underminded999's Avatar
Quoted: 29 Post(s)
I use monoprice b/c of the price. Assuming, you aren't loosing $, then any brand would work.(ducks for cover, from the snake oil merchants...)
underminded999 is offline
post #10 of 33 Old 03-06-2013, 06:55 PM - Thread Starter
mawnkey's Avatar
LOL sounds good I think they may be cheaper. That and instant gratification lol
mawnkey is offline
post #11 of 33 Old 03-07-2013, 09:53 PM - Thread Starter
mawnkey's Avatar
Okay I have my set up running with the receiver and my center. Where should I set my crossover?
mawnkey is offline
post #12 of 33 Old 03-07-2013, 10:22 PM
GregLee's Avatar
Quoted: 826 Post(s)
Liked: 263
80Hz. (But it's arguable.)
Greg Lee
GregLee is online now
post #13 of 33 Old 03-07-2013, 10:35 PM - Thread Starter
mawnkey's Avatar
Will do. Iv noted my speaker sounds great but with certain songs it doesn't sound so good with the bass. How can I modify so it doesn't sound like that?
mawnkey is offline
post #14 of 33 Old 03-07-2013, 10:48 PM
GregLee's Avatar
Quoted: 826 Post(s)
Liked: 263
Run the YPAO calibration program, if you haven't yet. Try different room positions for the subwoofer. (A lot has been written about getting good bass from a sub.)
Greg Lee
post #15 of 33 Old 03-08-2013, 08:53 AM - Thread Starter
mawnkey's Avatar
I will look for some material on sub location. It's kinda pointless to run it right now since I only have one speaker. Tomorrow I get the rest so ill run it then
mawnkey is offline
post #16 of 33 Old 03-08-2013, 10:46 AM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
After you get all your speakers hooked up, and after you run the auto calibration program, set all speakers to "small" with a crossover of 80hz.
A good method of finding the prime sub location is the SUB CRAWL.
Alan P is online now
post #17 of 33 Old 03-08-2013, 11:57 AM - Thread Starter
mawnkey's Avatar
Thank you Alan. What's the reason for the small speaker setting vs the large speaker setting?
mawnkey is offline
post #18 of 33 Old 03-08-2013, 12:01 PM
JD in NJ's Avatar
Liked: 36
Because if you set your speakers to 'small' (which is a terrible misnomer for the intent of that setting) then your AVR will redirect low frequencies from that speaker channel to the subwoofer.
JD in NJ is offline
post #19 of 33 Old 03-08-2013, 12:03 PM
Alan P's Avatar
Liked: 3326
Well, it is debatable, but the short answer is: 80hz is where the directional bass frequencies begin - if you send any frequencies above 80hz to your sub, you risk localization. Not a problem if your sub is close to your FL/R speakers, but if (like most) you have to put your sub along a side wall or behind the MLP, localizing it is not something you want.
One thing I should have mentioned that is quite important: if your AVR's auto calibration sets any of your speakers at a crossover higher than 80hz, you should not lower it. Only raise speakers that the auto cal set lower than 80hz.
EDIT: Geez, I should really read the question, eh? What JD said. biggrin.gif
post #20 of 33 Old 03-08-2013, 12:03 PM - Thread Starter
mawnkey's Avatar
That makes good sense. Thanks
mawnkey is offline
post #21 of 33 Old 03-08-2013, 12:57 PM - Thread Starter
mawnkey's Avatar
I'm not so sure on how I can change the cross over individually. I see a crossover for all of them
mawnkey is offline
post #22 of 33 Old 03-08-2013, 12:57 PM - Thread Starter
mawnkey's Avatar
mawnkey is offline
post #23 of 33 Old 03-08-2013, 01:00 PM
JD in NJ's Avatar
Liked: 36
Then generalize the advice to "if the crossover is set to below 80, raise it to 80. If it's above 80 leave it alone".
To be fair, some folks like a slightly higher crossover for various reasons, and there's no harm in experimenting with it a bit to see if it works better for you at, say, 100.
JD in NJ is offline
post #24 of 33 Old 03-08-2013, 02:15 PM
Alan P's Avatar
Liked: 3326
Yeah, personally I use 120hz (OMG, the horror! smile.gif ). Of course, that is subject to change because I'm still dialing in my new subs, but for now, I like how it sounds at 120hz. biggrin.gif
post #25 of 33 Old 03-08-2013, 05:15 PM - Thread Starter
mawnkey's Avatar
LOL alright ill play with it
mawnkey is offline
post #26 of 33 Old 03-11-2013, 09:04 PM - Thread Starter
mawnkey's Avatar
It's all set up now. I watched Prometheus yesterday and I had it to 7.1 audio. Is that correct even though its a 5.1?
mawnkey is offline
post #27 of 33 Old 03-12-2013, 05:41 AM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
What do you mean that you "had it to 7.1 audio"? If you mean you played the 7.1 track, that's OK. As long as you configured your receiver as 5.1 when you set it up, the AVR will make sure the data for the rear channels is downmixed into the surrounds.
BIslander is offline
post #28 of 33 Old 03-12-2013, 12:13 PM - Thread Starter
mawnkey's Avatar
I mean that the bluray is sending 7.1 audio into the reciever but if it mixes the backs and the sides then I'm good
mawnkey is offline
post #29 of 33 Old 03-12-2013, 12:29 PM
Alan P's Avatar
Liked: 3326
Well, the Prometheus Blu Ray only has DTS MA 5.1 so you are not getting 7.1 into the AVR with that disc.
If you want sound from your surround back speakers with 5.1 content, you will have to use the Dolby PLIIx or DTS NEO 6 surround setting to matrix SR/SL info into the back channels.
post #30 of 33 Old 03-12-2013, 12:51 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Why do you say the receiver is sending 7.1?
