Which wires can be used for subwoofer and pre to amplifier - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-10-2013, 05:23 PM - Thread Starter
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Hey guys, when connecting either a subwoofer or an amp to a preamp/receiver using RCA cables, is it ok to use digital coax cables? Or should you stick with specific Audio RCA and Subwoofer RCA cables? Is there any difference? Reason I ask is I can get better pricing on Digital coax then subwoofer/audio RCA cables specifically.
04rex is offline
post #2 of 4 Old 03-10-2013, 05:46 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
The "digital" cables will be fine. Many "analog" cables actually use the same coax.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 4 Old 03-10-2013, 05:57 PM - Thread Starter
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Ok cool. So no lose of signal or any other problems, especially for the sub? What about using component cables? I have a few of those laying around.
04rex is offline
post #4 of 4 Old 03-10-2013, 07:35 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
Video and digital audio both use 75 ohm coax cables. So, yes, a component video cable will be fine.
BIslander is offline
