Having problems with voice level in home theater.... persistant problem.. help please.. - AVS Forum | Home Theater Discussions And Reviews
Old 03-10-2013, 07:59 PM - Thread Starter
Rash1's Avatar
OK, i'm sure this subject has been dealt with, but after trying a lot of setups, i still have trouble with this situation.. My previous setup was a pionner Elite VSX 82 with Axiom speakers 5.1 Epic 500 setup. My Blu ray was my PS3 so maybe there is part of the equation but with my DVD player of another make same problem: When i listen to a movie soundtrack , the voices are WAY less loud then all other action and effects noise... This is so bad that i have to play with the volume on my remote continuasly or everthing is exploding in action and wispering in voices. Don't worry, i played around with the dynamic range compression on the PS3 and or dvd player, as well as on the Pioneer amp... tried direct, and all formats of dolby and digital on my amp. I also tried to increase db on the center channel on the amp as well.... The problem stays there. The problem seems a lot worse when i Watch translated french versions., even in 5.1 digital, and also seems worse if sound level is low. So when i play loud and in original English soundtrack, its tolerable.. but in normal day to day watching, its always a problem...
The good news is i am moving and am going to re do a new system.. so now is the time to plan ahead...
what do i need to do to solve this..
thanks...
i'll do what i have to...
Rash1 is offline
Old 03-10-2013, 11:47 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
The placement of the center speaker can affect performance. Is it hidden away? Also, have you calibrated the output levels of your speakers?
BIslander is offline
Old 03-11-2013, 05:54 AM - Thread Starter
Rash1's Avatar
Done that...
Uploaded with ImageShack.us
Rash1 is offline
Old 03-11-2013, 06:10 AM
MikeyD360's Avatar
Liked: 26
I've heard vocal issues can be due to reflections in the room - judging by your bare walls and hardwood floors, this could be your problem. Might be worth seeking room treatment advice from someone knowledgable.
MikeyD360 is offline
Old 03-11-2013, 06:46 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Yes, the system seems to be amazingly lacking in absorption or even diffusion.
Looks to me like someone put a thin layer or cork on the ceiling, but if it is what it appears to be, its spitting in the wind.
Also, there are some things that might be done with eq, but no indication that the OP has gone there.
arnyk is offline
Old 03-11-2013, 07:29 PM - Thread Starter
Rash1's Avatar
The ceiling is acoustic absorbing cork and extérior walls are 6 inch with insulation... the room is actually probably quite muffled... when you walk in it, you can hear the noise become dead.. no echo there... but i'll look into that possiblité.. by the way,, i am in another envrionnement right now, and in a normal environnement i.e. none insulated walls, it is much worse.. so i think there is more to do
acoustic cork: http://www.lusimat.ca/cork_soundproofing.asp
i really don't think the sound resonance is a problem in that room...
Rash1 is offline
Old 03-11-2013, 08:21 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
the mid and high frequency sounds don't see the insulation behind walls they bounce off of, so it makes no difference for this purpose. I'd be shocked if you can't hear flutter echo if you clap your hands in that room. Just like I can in my room with carpeted floors, gyp board walls and ceilings.
JHAz is offline
Old 03-11-2013, 08:51 PM - Thread Starter
Rash1's Avatar
OK maybe.. but anyway.. do you really think that is the only problem?? my house burned down january 1 so i will build a new theater room.. i can adress this problem, but i 'm not sure it is such a major problem... is there a precise way of knowing if there is too much sound resonance in the room ?
Rash1 is offline
Old 03-12-2013, 08:24 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
Sorry to hear about your house. I was really just responding to the narrow issue of whether insulation behind a wall improves room acoustics. You'd need more than a casual discussion on an internet board to assess the acoustics of any room. But generally it's big untreated sapces (AFAIK) that most interfere with speech comprehension. Like a gym or a train station. When my kids swam competetively indoor pools sounded awful and it could be hard to understand the announcements. IMO chances are a lot of what you're responding to is simply the way the movies are mixed.
JHAz is offline
Old 03-12-2013, 09:42 AM
flickhtguru's Avatar
Liked: 110
thanks...
Have you always had this issue? Did you have or hear this issue with any other speakers?
I have never heard Axiom speakers so I don't want to bash how they actually sound, BUT in theory they have some of the worst designed Center Channel Speakers on the market. Having 3 mids or woofers side by side in the center of the speaker and then a tweeter flanking on each side doesn't seem to theoretically work. I believe that would cause huge comb filering and also very different sound as one moves from left to center to right in the room. So every seat will have a different sound.
Shawn
flickhtguru is offline
Old 03-12-2013, 02:12 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
+1
Most furnished residential rooms are not acoustically "untreated" spaces. There may be some opportunity for improvement through room treatments, but it's naive to assume room treatment without evidence.
I say without evidence, as the first thing to look at is the source, in this case a good center channel. This one is not designed correctly to be a good CC. 2 tweeters flanking 3 mid-woofers is asking for odd acoustic effects across the sound stage. Ideally, you'd like a WTMW with the TM arranged vertically (Axiom VP-160), or a purpose-build MTM CC with a tight mid-woofer C-C spacing, and a very small, very good tweeter that can support a low crossover frequency. (Note that this may not include the other Axiom CCs) Voices should be easy to understand even when played very softly.
Have fun,
Frank
fbov is offline
Old 03-12-2013, 08:51 PM - Thread Starter
Rash1's Avatar
Thanks for the constructive comments.. it seems Axiom aren't that great in the center, granted, thats possible.. keep in mind, i have a clean slate right now because i am moving into a new house in 3 months.. so i can do whatever setup i want or almost... First.. if i have a way of measuring echo or resonance of a room it would be helpfull instead of just muffling out everything ... secundo... i probably won't go with axiom..so i am open to any make in the 4000$ range for 5.1 setup... and i'm not sold on Pioneer Elite either.. with a 2000$ budget for amp let's hear suggestions.. But.. don't forget.. it seems the TRANSLATION into french 5.1 is also a big part of the problem...cause in 5.1 English it is a lot less of a problem.. so i guess... i have to up the power on the center channel with the french versions.....
work in progress...
Rash1 is offline
Old 03-12-2013, 09:26 PM
GregLee's Avatar
Quoted: 825 Post(s)
Liked: 262
I have two HTs at the moment with Pioneer receivers and Axiom speakers as center channels: M2i (not designed as a center channel) in HT2 and VP180 in HT1. Before getting the VP180, I used a VP150 as center in HT1. I have had no problem at all with dialog using these 3 Axiom speakers, so I am very skeptical that Axiom somehow got the design of their centers speakers wrong. The combination I have now in HT1 of center speaker VP180 and Pioneer SC-1522-K receiver is giving me the best separation of dialog from music and effects I have heard.
Greg Lee
GregLee is online now
Old 03-12-2013, 09:34 PM - Thread Starter
Rash1's Avatar
OK.. so maybe its mostly the setup, and the damn translations... my girlfreind only speaks french..(wich isn't a very big problem...wink..wink..) but she wants her tv in french...and that IS a big problem...
thanks for the comments.
Rash1 is offline
Old 03-13-2013, 03:48 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3326
You say that you have calibrated all speaker levels - not to doubt you, but did you calibrate to 75db with a SPL meter? (Just trying to cover all bases here.)
You said that even raising the center speaker level did not help - that seems very odd to me. Are you absolutely sure the center speaker is producing sound at all? When you put your ear to it, what do you hear?
Alan P is online now
Old 03-13-2013, 03:50 PM
Alan P's Avatar
Liked: 3326
One more thing - a lot of times, the translated audio is in a different format - even 2.0. Have you made sure you are in the correct surround mode for the audio source? For 2.0 you should try Dolby PLIIx or similar.
Old 03-13-2013, 06:03 PM
Rob-Houston's Avatar
Quoted: 123 Post(s)
Liked: 68
French women ARE high maintenance. It'll be a lot cheaper in the long run to replace with an English speaking model! rolleyes.gif
Rob-Houston is offline
Old 03-14-2013, 07:57 PM - Thread Starter
Rash1's Avatar
who knows... actually, i have too much invested in the actual model... so i guess i'll change centre speakers...
Rash1 is offline
Old 03-14-2013, 08:26 PM
HopefulFred's Avatar
Quoted: 490 Post(s)
Liked: 422
HopefulFred is offline
Old 03-15-2013, 08:16 PM - Thread Starter
Rash1's Avatar
thanks, .. now that is good information...
i probably had bad acoustics...
now i am building a new theater room.. .where do i start to avoid this problem...
Rash1 is offline
