Soundbar hookup issue - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-19-2013, 05:32 PM - Thread Starter
polkguy1123's Avatar
Let me start by saying that I need things explained pretty simple as this is all new to me.
I just bought an Insignia HDTV and a polk 3000 soundbar. The only other thing I am running is a charter cable box.
I currently have a hdmi cord running from the cable box to the tv. I have a cable(picture headphone jack ends) running from the soundbar to the tv. I have sound but I know this is not the best way to hook it up.
The soundbar has an optical audio as does the cable box, but the tv does not. I hooked it up to the soundbar and to the cable box, but no audio.
Any help? Thanks
polkguy1123 is offline
post #2 of 21 Old 03-19-2013, 05:44 PM
K Shep's Avatar
Run an optical wire from the cable box to the sound bar.
K Shep is offline
post #3 of 21 Old 03-19-2013, 05:48 PM - Thread Starter
K shep, I tried that and no sound.
post #4 of 21 Old 03-19-2013, 05:57 PM
K Shep's Avatar
What type of cable box do you have? I have a Motorola/Comcast.
K Shep is offline
post #5 of 21 Old 03-19-2013, 05:59 PM - Thread Starter
It is a Motorola dcx3501-m
post #6 of 21 Old 03-19-2013, 05:59 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
I don't understand why you are not getting sound when you use the optical cable from the cable box to the soundbar. That should work. Maybe the cable box has some setup control to tell it to send a signal out through the optical connection? (I have a foggy recollection that one of my cable boxes worked this way, a long time ago.)
If your TV is hooked to an antenna, as well as the cable box, you're not going to get sound from over-the-air channels through the soundbar if the soundbar is not connected to the TV.
Greg Lee
GregLee is offline
post #7 of 21 Old 03-19-2013, 06:08 PM
K Shep's Avatar
Are you using the optical cable supplied by Polk? If you have another optical cable try it. You tried the 1/8" to RCA adapter from your TV to the sound bar and got it to play but not the best sound, is that correct?
K Shep is offline
post #8 of 21 Old 03-19-2013, 06:21 PM - Thread Starter
Yes, the optical cable from polk. I dont have another one, but can get one tomorrow. Right now I am running the 1/8" without the adapter fom the soundbar to the headphone jack on the tv. That was the only way I could get any sound. The sound isn't bad, but I figured it wasnt the best connection.
post #9 of 21 Old 03-19-2013, 08:13 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
I looked up the manual for the soundbar, and in the trouble shooting hints I see this:
Check that the audio format of the input source is set to PCM 2-channel audio.
Did you do that? (I guess you'd have to tell your cable box this, somehow.)
Greg Lee
GregLee is offline
post #10 of 21 Old 03-19-2013, 08:22 PM - Thread Starter
I did see that. I can't seem to figure out how to change that on the box though.
I guess the other question is, is the way i have it hooked up right now a good way to do it or would i notice a difference hooking it up a different way?
post #11 of 21 Old 03-19-2013, 09:49 PM
GregLee's Avatar
Quoted: 868 Post(s)
Liked: 296
The big advantage an optical connection has is that it can carry a Dolby Digital 5.1 signal, while a simple left+right stereo connection gets you only two channels. But it appears that your soundbar only allows a two channel input, anyway, so I don't know that there is any advantage in using the optical connection.
Greg Lee
GregLee is offline
post #12 of 21 Old 03-20-2013, 04:41 AM
Ratman's Avatar
Quoted: 1438 Post(s)
Liked: 1148
Page 38 of the manual shows that the output can be changed to L-PCM.
http://www.wavebroadband.com/support/cable/docs/DCX3501M-Installation-Guide.pdf
Also, you did remove the protective caps from the ends of the optical cable, right? wink.gif
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Ratman is online now
post #13 of 21 Old 03-21-2013, 06:15 AM - Thread Starter
Ok, I went back to the place i bought the tv and soundbar yesterday. Apparantly the only way this setup will work is through my headphone jack. It sounds fine, but I'll never know if I'm getting all I can out of it. Thanks for all the help.
post #14 of 21 Old 03-21-2013, 06:29 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
Please read:
http://www.polkaudio.com/downloads/manual/IHT3000MN_ENG.pdf
page 7.
arnyk is offline
post #15 of 21 Old 03-21-2013, 07:24 AM - Thread Starter
Arnyk, I just read that and I agree that I should be able to hook it to the cable box. The problem is when i hook it to the cable boxes optical output I still get no soynd even with the setting set to pcm. Either it just won't work that way or the audio outputs on the box are not working.
post #16 of 21 Old 03-21-2013, 08:00 AM
K Shep's Avatar
PolkAudio Customer Service 800-377-7655 (Outside USA & Canada: 410-358-3600)
K Shep is offline
post #17 of 21 Old 03-21-2013, 08:29 AM
Ratman's Avatar
Liked: 1148
Are you sure that the TV doesn't have an optical output? That seems strange that an HDTV (with an internal tuner) doesn't have an optical output. Also, it may be that the optical input of the soundbar isn't working. wink.gif
post #18 of 21 Old 03-21-2013, 08:37 AM - Thread Starter
Yeah, no optical, just the Orange digital output jack on the tv.
Would the digital coxial cord with an adapter to 1/8" to go into the soundbar be a better connection than I have now?
post #19 of 21 Old 03-21-2013, 10:51 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1241
The following looks like it could convert the coax (orange) output of the TV (Exact model number?) to optical for the sound bar digital input:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2947&seq=1&format=2
This would give you the best possible sound quality.
arnyk is offline
post #20 of 21 Old 03-21-2013, 12:40 PM - Thread Starter
Thanks, I will see if I can find one locally. Tv model is Insignia 55" 1080p lcd NS-55L260A13
post #21 of 21 Old 03-21-2013, 01:48 PM
Ratman's Avatar
Liked: 1148
You probably will not find a coax to optical converter locally. Even if you do, it won't be $15.00.
IMHO, use the 'audio out/headphone" output or you can buy/try the converter from Monoprice. Either way, It probably won't make a dramatic difference in sound quality (if any).
