Can I connect 200 ohm output impedance to 8 kilo ohm input impedance? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-20-2013, 09:11 AM - Thread Starter
rrsuj's Avatar
I have an Alesis DEQ230 Graphic EQ, where the audio output impedance is 220 Ohm. I want to connect it to my Logitech Z5500 speaker, where the input impedance is 8 KOhm (http://reviews.cnet.com/pc-speakers/logitech-z-5500/4507-3179_7-31115626.html).
So my question is- can I connect them directly with the 2x 1/4 mono male jack to 3.5mm stereo female jack (similar to http://www.amazon.com/Hosa-CMP159-Stereo-Breakout-10-Feet/dp/B005HGM1D6/ref=pd_bxgy_MI_img_z)?
rrsuj is offline
post #2 of 5 Old 03-20-2013, 10:11 AM
SAM64's Avatar
Liked: 78
Yes. This is how modern audio systems are interconnected.
Impedance matching went out in the 60's.
SAM64 is offline
post #3 of 5 Old 03-21-2013, 02:39 AM - Thread Starter
rrsuj's Avatar
Thank you for the information.
rrsuj is offline
post #4 of 5 Old 03-21-2013, 12:32 PM
Glimmie's Avatar
Quoted: 748 Post(s)
Liked: 618
+1
Glimmie is online now
post #5 of 5 Old 03-21-2013, 09:33 PM
whoaru99's Avatar
Liked: 69
To third it, the rule of thumb I've seen is 1:10 or better. Those numbers easily surpass that at about 1:36.
Just because there is a knob doesn't mean you should turn it.
whoaru99 is offline
