Why does simulated 5.1 sounds better/louder than stright 2.0/2.1 ? (Yamaha V373) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 19 Old 03-20-2013, 09:49 AM - Thread Starter
faire's Avatar
Hi folks, first of all let me tell you that I'm a noob on this topic (big news):
This is my setup :
XBMC on Windows 8 HTPC (HDMI) > Receiver > LED LG TV
I have a 5.1 setup speakers attached to my receiver.
So, whenever I listen to a stereo song or video and the receiver plays it in straight mode... it sounds softer, less warm, less bass than when I choose the Music 5.1 mode (I guess the receiver makes a 2.0->5.1 conversion).
I don't know if I'm misunderstanding the conception on good and bad sound.. or I just have to adjust volume up every time that I listen to stereo songs...
I've read in many forums that Stereo has to be played as stereo and that's why I would like to listen in straight mode. What do you usually do here? Do you play your stereo songs using your 5.1 speakers or just in straight mode using only your 2 front speakers?
Do you experience the same as me regarding straight mode vs 5.1 when listening to stereo sources?
Do you guys know any guide with tips on how to calibrate a yamaha receiver better???
faire is offline
post #2 of 19 Old 03-20-2013, 01:50 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
when your receiver creates 5.1 channels from 2.0 channels, it doesn't (probably) turn down the stereo program, just adds sound from the other speakers. "adds sound" kinda suggests it'll be louder. Equal loudness curves demonstrate that louder = sounds like more bass. So that may be part of the deal. Also may be the way your particular receiver manufactures the multichannel from the stereo input.
I like (conservatively) creating MC from my stereo discs and I do it most of the time. Others feel that it was mixed in stereo, and should be heard as mixed. I have no beef with that view.
IMO, do what you like. (In 5/4 if you're Blind Faith)
JHAz is offline
post #3 of 19 Old 03-20-2013, 02:02 PM
GregLee's Avatar
Quoted: 800 Post(s)
Liked: 259
I play stereo using as many channels as I can, which happens to be 9. If I ever heard that I should use only as many channels as are distinct in the source signal, I must have let that go out the opposite ear from where it came in. The most obvious case where you should use more output channels than two is a movie soundtrack designed by the audio engineer to be played using Dolby ProLogic for more than two outputs.
Greg Lee
GregLee is offline
post #4 of 19 Old 03-20-2013, 03:21 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
Count me in as another that converts 2ch to 5.1
I use my Yamaha AVR's '7ch Stereo' mode to do so. The beauty of it is that you can go into the parameters of that particular mode and adjust the extra speakers volume level in 1% increments from 0 to 100% of the front L/R signal level. At the moment I have my centre speaker at 29% and the side surrounds at 47%. The bulk of the soundstage is still up front but it is now wall to wall with depth and good localisation and a sense that you are in the room with them (or they're in my room with me) Straight 2ch playback sounds flat in comparison.
As you noted, it also sound louder as well. This is an advantage as the front speakers don't need to play as loud to reach the same dB that you want to hear at the listening position. This will reduce distortion and driver compression and such.
Also another advantage if set up correctly, is that the frequency response at the listening position will be smoother. Say you have your front speakers in a place in the room that produces a dip in the frequency response around 1k. Your side surround speakers will be in a different part of the room and may not be producing that 1k dip. When all measured together the surround sound upmix will produce a smoother flatter FR. Same principle as having multiple subs around the room.
kiwi2 is offline
post #5 of 19 Old 03-20-2013, 03:40 PM - Thread Starter
faire's Avatar
You can adjust only front speakers? or all of your speakes? I didn't understand why you mention only front L/R speakers but you set your surround speakers at 47%. I'm misunderstanding something for sure.
Why do you prefer "7ch Stereo" over those Dolby Pro Logic (don't remember the name) functions that the receiver does by converting stereo sound into "real"/ simulated surround sound ? I understand the difference is that while 7ch or 5ch stereo sends the same signal to all speakers, those Pro Logic modes attempts to create a surround mode by sending high or low signals to the surround speakers right?
faire is offline
post #6 of 19 Old 03-20-2013, 04:53 PM
kiwi2's Avatar
Quoted: 35 Post(s)
Liked: 160
I can adjust any extra speakers (centre, side surrounds) relative to the front L/R in a percentage of the front L/R signal. You can make it as subtle or as in your face as you prefer. By default '7ch Stereo' mode plays the side surrounds at 100% which is way too much I find. Once you get into the parameters and adjust to taste, it starts to make sense.
There is less control with those other modes (they do have some parameter adjustments that they are very crude in scale) and they just don't sound as good to me. On some songs they work okay and on others they don't work as well. It's a bit more hit and miss.
kiwi2 is offline
post #7 of 19 Old 03-20-2013, 07:52 PM
Kilian.ca's Avatar
Liked: 37
If using Dolby PLII Music mode there is more bass by design, more info here, esp. post 9:
http://www.avsforum.com/t/1405366/bass-drastically-different-between-plii-music-vs-pliiz-height
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
post #8 of 19 Old 03-21-2013, 06:16 AM - Thread Starter
faire's Avatar
Thank you guys for all your replies.
Just one more question.. do you usually equalize your speakers? On my receiver I can add more treble, middle or bass to each speaker.. do you usually add bass to your speakers despite your subwoofer?
faire is offline
post #9 of 19 Old 03-21-2013, 10:54 AM
GregLee's Avatar
Quoted: 800 Post(s)
Liked: 259
No, I leave all my receiver settings just where the calibration system puts them, with the exception that I change my surround speakers from the "large" setting to "small". I hand tune the volume and crossover controls on my subwoofers (however, most would probably recommend against this).
Greg Lee
GregLee is offline
post #10 of 19 Old 03-21-2013, 02:59 PM - Thread Starter
faire's Avatar
I have my front speakers (towers) set as large. YPAO configured them like that although I ran the calibration before I got my subwoofer. I've seen most of you have them as "Small". What's the difference?
faire is offline
post #11 of 19 Old 03-21-2013, 03:09 PM
GregLee's Avatar
Quoted: 800 Post(s)
Liked: 259
With the "small" setting, the receiver routes bass away from the speaker and to the subwoofer. With the "large" setting, all the sound in the channel the speaker is supposed to be playing is routed to the speaker. As with many things audio, there is no complete agreement, but the consensus is that "small" is best. (It's a subject in itself.)
Since you added a subwoofer, I think you should re-run YPAO.
Greg Lee
GregLee is offline
post #12 of 19 Old 03-21-2013, 03:23 PM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
+1
GL, I just noticed where you're located. Color me jealous. Snow here in teh midwest today . . .
JHAz is offline
post #13 of 19 Old 03-21-2013, 05:01 PM - Thread Starter
faire's Avatar
I re-ran YPAO now that I have a subwoofer but it keeps setting my front speakers to large. I have the crossover freq set to highest on the subwoofer according to YPAO instructions.
These are YPAO results:
FRONT L : 0.0 db | Large
FRONT R: 0.0 db | Large
Center: -1.5 db | Small
SUR L: +5.5 db | Small
SUR R: +7.0 db | Small
SUBWoofer: -9.0 db | Phase: Normal
Crossover: 120hz
Extra Bass: off
Distance:
Front L : 5.4 ft
Front R: 5.2 ft
Center: 4.8 ft
SUR L: 5.2 ft
SUR R: 5.6 ft
SUBW: 7.8 ft
any ideas?
faire is offline
post #14 of 19 Old 03-21-2013, 05:10 PM - Thread Starter
faire's Avatar
I have set speakers to small, crossover to 80hz and SW levels to -6.0 db. Does that make sense to you¿
faire is offline
post #15 of 19 Old 03-21-2013, 05:48 PM
GregLee's Avatar
Quoted: 800 Post(s)
Liked: 259
Yes, that sounds like a sensible setting.
Greg Lee
GregLee is offline
post #16 of 19 Old 03-22-2013, 02:05 AM
Kilian.ca's Avatar
Liked: 37
SUBWoofer: -9.0 db from YPAO indicates the volume was a bit too higher to begin with. Ideally after calibration the levels should be as close to 0 as possible to allow headroom each way.
The sub distance from YPAO should not be less than the actual physical distance, usually more.
post #17 of 19 Old 03-22-2013, 06:22 AM - Thread Starter
faire's Avatar
So should I set the SW level to 0 db ?
faire is offline
post #18 of 19 Old 03-22-2013, 09:37 AM
JHAz's Avatar
Quoted: 305 Post(s)
Liked: 271
not without adjusting the sub's own volume level. (that's why Killan said "the volume level was a bit too high to begin with"). You want all the sspeakers to be equally calibrated, at least to start with. YOu can adjust to taste later. Theoretically, as long as your sub can be calibrated without "hitting the stops" is without going to the greatest plus or minus calibration available, it should be calibrated correctly. Many like their sub calibrations to be closer to zero for a variety of potential reasons. But you need not follow that approach unless you have some reason to do so.
JHAz is offline
post #19 of 19 Old 03-24-2013, 07:41 PM
SteveCallas's Avatar
Quoted: 138 Post(s)
Liked: 56
I used to listen in stereo......can't see ever going back from ProLogic IIx with Audessy DSX 9.2 with wides.
SteveCallas is offline
