Playing music from hard drive to stereo system via RCA cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-21-2013, 05:25 PM - Thread Starter
Harlen's Avatar
I have an older high end stereo system that only accepts RCA cabled input. I want to digitally record my CDs, store them on a high capacity storage device along with downloaded music files, connect that device to my system and control the playback using my iPhone.
Is there such a device? I essentially want to replace the 300 CD changer currently connected to the system.
Harlen is offline
post #2 of 9 Old 03-21-2013, 08:01 PM
underminded999's Avatar
Quoted: 29 Post(s)
You are going to need a Digital to Analog Audio Converter via USB. A la http://www.parts-express.com/pe/showdetl.cfm?partnumber=180-998
However, I don't know how you wold interface with the digital media.
-_999_-
underminded999 is offline
post #3 of 9 Old 03-21-2013, 08:06 PM
Bigus's Avatar
Quoted: 196 Post(s)
Liked: 223
Certainly possible. One obvious route is a PC (computer) connected to your stereo. There are many options and hardware choices depending on whether you'd prefer to simply connect an existing computer you use, or buy/build a dedicated machine and if so what other tasks might you want it to handle (serving video as well as music, pictures, other household desktop computing tasks, central household file server...?). There are also many software options from free to not cheap, from dedicated music only to all purpose music/movie/picture warehouse and streamer/player.
Bigus is offline
post #4 of 9 Old 03-21-2013, 08:25 PM
Kal Rubinson's Avatar
Quoted: 673 Post(s)
Liked: 460
SImplest would be a Sonos or (now discontinued) SqueezerBox Touch system.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #5 of 9 Old 03-26-2013, 05:53 AM
Mookalafalas's Avatar
This is a question in a similar vein. I just noticed that all new DVD and blu-ray players include a USB connection in the front. Is there any way to play music files on my PC through a USB out into a DVD/Blue ray and then into my stereo?
Mookalafalas is offline
post #6 of 9 Old 03-26-2013, 06:00 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
Aren't there AVRs that provide similar facilites either via USB or via network connection and DLNA?
arnyk is offline
post #7 of 9 Old 03-26-2013, 07:48 AM
Quoted: 673 Post(s)
Liked: 460
Yes but, so far, their GUIs are quite limited and it is hard to manage large music collections.
Kal Rubinson
post #8 of 9 Old 03-26-2013, 10:30 AM
Nethawk's Avatar
Liked: 118
+1 on Squeezebox Touch recommendation. I used the same setup for years (first with Roku then Squeezebox classic). It's easy, relatively economical and offers more flexibility than most alternatives.
Nethawk is offline
post #9 of 9 Old 03-31-2013, 06:00 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The problem is that there are two types of USB connections and they are not clearly marked. The USB connections on PCs and Blu Ray players present a host interface. Flash and external hard drives present a mass storage interface. One of each is required for a working connection.
arnyk is offline
