Motherboard 3.5mm analog sound to either digital coax or toslink? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 03-22-2013, 11:57 AM - Thread Starter
krmarks's Avatar
Can anyone help me solve this:
I have an HTPC I just built and I have this motherboard: http://www.biostar-usa.com/app/en-us/mb/introduction.php?S_ID=615
From the motherboard, I would like to have the sound come out and go into my Sony soundbar: http://store.sony.com/p/HT-CT150/en/p/HTCT150
I have an open Toslink and an open Digital coax. I can't use HDMI sound because I have my PS3 screwing up using the soundbar as a monitor.
So long story short I have 6 analog outs on the motherboard and 1 digital coax or 1 toslink port available. Any suggestions?
krmarks is offline
post #2 of 9 Old 03-22-2013, 12:41 PM
intangiblefatman's Avatar
A USB audio interface like the one below would give you an optical output to connect to the sound bar.
http://www.amazon.com/Behringer-UCA202-Audio-Interface/dp/B000KW2YEI/
intangiblefatman is offline
post #3 of 9 Old 03-22-2013, 01:41 PM - Thread Starter
krmarks's Avatar
Thanks, if I have to go that route, I will probably just buy a PCI card with toslink or coax out. I was hoping to get by with a solution that didn't involve more money since I have a million different cables in my cable/hardware container at home.
krmarks is offline
post #4 of 9 Old 03-22-2013, 01:54 PM
scardeal's Avatar
Worst case scenario - 3.5mm to dual RCA analog connection
scardeal is offline
post #5 of 9 Old 03-22-2013, 02:24 PM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
Doesn't the Biostar Hi-Fi A85W Ver. 5.x mb also have an internal S/PDIF-OUT Header on the board you could use?
_
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
post #6 of 9 Old 03-22-2013, 03:14 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Krmarks,
. . . I have an open Toslink and an open Digital coax.
As SoundChex suggested, there is and S/PDIF output on the motherboard (Toslink and digital-coax are both forms of S/PDIF). So it is simply a matter of getting the right cabling to directly connect the motherboard's S/PDIF output to the Sony's digital-coax.
MarkHotchkiss is offline
post #7 of 9 Old 03-22-2013, 03:48 PM - Thread Starter
krmarks's Avatar
Yes there is a SPDIF header on the board, but how do I utilize it? I am not sure how I hook a toslink up to that.
krmarks is offline
post #8 of 9 Old 03-22-2013, 04:24 PM
Liked: 85
Hi Krmarks,
Ten bucks.
http://www.ebay.com/itm/Biostar-SPDIF-Digtial-COAX-Audio-Cable-27-K12-033040R5-/221019107039?pt=LH_DefaultDomain_0&hash=item3375c3eedf
post #9 of 9 Old 03-22-2013, 05:04 PM - Thread Starter
krmarks's Avatar
Thanks Mark, I ordered one. I appreciate it. I hadn't seen that part before, go figure.
krmarks is offline
