Center speaker importance in small room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-22-2013, 04:02 PM - Thread Starter
skkayman's Avatar
Hi everybody smile.gif I am buying a new fronts and I am thinking about center speaker too. (I would use old speakers as surround as they are not that important to have matched with fronts).
Problem is space for me (http://img13.imageshack.us/img13/166/repro1.png), I would have to move desk lower to make space for center speaker and buy holder for LCD. So I am thinking if I need center speaker. I tried small speaker as center and only difference was that all dialogs were from center - it was easier to hear dialogs. But that's all? Without center speaker the voices do not comes from monitor but from space arround me.
I am just thinking if it is worth it.. Seller from who I plan to order speakers told me that he thinks in that small space it is not worth buying center. But I heard difference with it
skkayman is offline
post #2 of 4 Old 03-22-2013, 04:29 PM
Alan P's Avatar
Quoted: 4697 Post(s)
Liked: 3324
How far away do you sit from the display when watching? If you're not right up on it, the "phantom" center effect should work pretty well for you (with you MLP being centered between the FL/R).
Alan P is offline
post #3 of 4 Old 03-22-2013, 04:36 PM - Thread Starter
skkayman's Avatar
only 70-80cm (27-31 inches) from monitor.
skkayman is offline
post #4 of 4 Old 03-27-2013, 03:47 AM - Thread Starter
skkayman's Avatar
I will buy fronts only. center speaker is hard to place and I would need monitor holder. So I hope that I do not need center smile.gif
skkayman is offline
