2" vs 4" deep absorbers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 03-29-2013, 01:34 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
I currently have absorbers setup on the side walls in my home theater / listening room. They are 1' wide and 3' long, 2" deep and mounted flush with the wall.
My question is will going with deeper and bigger absorbers improve the bass response in my room overall? I would make some that are 2' x 4' x 4". I made the absorbers in the first place to take care of "flutter echo" and early reflections from my ESLs but now I would like to build something a bit better since I can spare the extra few inches of wall space. I just wanted to know if it is going to be worth the time and effort and if I'll notice an improvement in bass.
Appreciate any advice
BB1111 is offline
post #2 of 21 Old 03-29-2013, 01:45 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Yes, absorbers on the side walls should be wider than one foot, unless you're literally three feet away from the loudspeakers or closer. Speakers radiate outward in an arc, so the term "reflection point" is a misnomer. It's really an area.
Early reflections is mainly a problem at mid and high frequencies, though making them thicker can only help. I wouldn't expect a lot of bass trapping from absorbers mounted there because bass tends to collect more in the corners. So I'd do both - larger panels at reflection points, plus bass traps in more suitable places such as the rear wall behind you.
--Ethan
Ethan Winer is offline
post #3 of 21 Old 03-29-2013, 08:21 PM
Nyal Mellor's Avatar
Quoted: 435 Post(s)
Liked: 312
Depending on how far your speakers are from the side walls using thicker products, preferably with a membrane in them somewhere, will help reduce speaker boundary interference related nulls from the sidewalls that often show up in the 100-300Hz region.
Want to learn about home theater design and acoustics? Read our blog.
Company: Acoustic Frontiers - design and creation of high performance home theaters for discerning audio/video enthusiasts.
Certifications: HAA Level I & II, THX Video Level I & II, CEDIA EST I & II.
AVS Projects: Too many to show in my signature - see here for the master list.
Nyal Mellor is offline
post #4 of 21 Old 03-30-2013, 12:41 AM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Currently bass at my MLP position is pretty good except for the 100-125hz range where I have a huge null. Just moving my head forward a foot brings back a lot of decibels in this range, this is in stereo without my subwoofer on and no Audyssey, it may help correct that when its turned on. Havent tested yet.
Mains are 4 feet from each corner. Overall a thicker absorber will be better? Also what sort of membrane is needed?
BB1111 is offline
post #5 of 21 Old 03-30-2013, 03:06 PM
Quoted: 264 Post(s)
Liked: 359
Huge nulls are common, and often due to reflections from the rear wall behind you. But they can also be SBIR as Nyal explained. It's not difficult to tell which is the cause, by moving the speakers sideways versus forward and back while measuring. Or use my Frequency-Distance Calculator to relate the exact frequencies you measure versus the exact distances. Either way you need to measure. This cannot be done by ear.
Yes, thicker absorbers are always better for bass frequencies. Membrane absorbers when implemented properly are better than plain rigid fiberglass.
--Ethan
post #6 of 21 Old 04-02-2013, 12:43 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
The easy answer is to test it, with your current absorbers, by pulling them out 2-4".
I've attached a couple charts from Everest's Master Handbook of Acoustics.
The first shows the effect of thickness for surface mounted panels. It supports the approach of using thicker panels to improve bass absorption.
However, when you reallize the data below is for the 1" thick panel, above, and that you're starting with a 2" panel, it seems as if you can simulate 4" panels by simply spacing your current panels away from the wall a few inches.
If this test shows the kind of improvement you're looking for, then you know it's worth the time and effort.
Regarding your 100-125Hz null, any chance your speakers are ~2.5' from the front wall? If so, put an appropriate panel on the front wall behind the speaker, to absorb the front wall reflection that's a likely contributor to the null. I've seen lots of data that sidewall reflections improve sound quality, conventional wisdom not withstanding, but none that say the front wall contributes anything desirable.
HAve fun,
Frank
fbov is offline
post #7 of 21 Old 04-02-2013, 01:06 PM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
regardless of thickness, the absorber still needs to be large with respect to wavelength.
localhost127 is offline
post #8 of 21 Old 04-02-2013, 02:16 PM
jim19611961's Avatar
Quoted: 449 Post(s)
Liked: 153
+1
My Room
My Music
Rega - Apollo, Rega - DAC, Goldpoint Passive, Classe CA-100, Crown XLS 1002, miniDSP
Jenzen Next
jim19611961 is offline
post #9 of 21 Old 04-02-2013, 03:22 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
HAve fun,
Frank
Heh, the speakers are almost exactly 2.5' from the front wall. The Martin Logans are pulled out as far as I can get them in this room. A thick absorber would be better for the wall behind the panel? I just made some skyline diffusers to help diffuse the rear backwave... the sidewalls have the 2" absorbers currently. I was told that absorbing the backwave will kill the spaciousness that an ESL is known for so I went with diffusers but I'm open to trying something different if it will improve sound quality.
Room is 14" W x 8" H x 20" L with the speakers firing into the length of the room. MLP is 10 feet from the back wall.
BB1111 is offline
post #10 of 21 Old 04-02-2013, 03:59 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2899
You're at the midpoint of room length? (which I'm guessing is 20', not 20")
Sanjay
sdurani is offline
post #11 of 21 Old 04-02-2013, 04:37 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
No, it's inches. I have a REALLY tiny room
I'm not sitting in the midpoint, about 3 feet in front of it. I think my original measurements are a little off, room is probably more like 18' deep.
BB1111 is offline
post #12 of 21 Old 04-02-2013, 05:08 PM
sdurani's Avatar
Liked: 2899
LOL, gives new meaning to "small room" acoustics.
That doesn't reconcile with your previous numbers: room is 20' long, MLP is 10' from the back wall (half of 20), which should be the midpoint of room length.
The reason I ask is to find out if there are ways to solve some of your frequency response problems using placement, augmented with treatments (e.g., bass traps) rather than trying to solve them primarily or solely with treatments.
Sanjay
sdurani is offline
post #13 of 21 Old 04-02-2013, 05:13 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
Re measured the length of the room. Seating position is 11 ft from the back wall and 8 feet from the front wall. If moving the speakers would help that would be great, as long as it doesn't cause problems else where in the frequency.
BB1111 is offline
post #14 of 21 Old 04-03-2013, 10:48 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Heh, the speakers are almost exactly 2.5' from the front wall. The Martin Logans are ....
Missed that... Any panel speaker has a special relationship with it's room. Many of the conventional tricks don't apply.
HAve fun,
Frank
fbov is offline
post #15 of 21 Old 04-03-2013, 04:57 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
A 2" panel with a 2" - 3" airspace is not going to absorb as well as a 4" panel without an airspace.
2.5' is about a quarter wave at 112 Hz.
My Maggies sound much better with the back wave heavily damped.
IMO - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #16 of 21 Old 04-03-2013, 09:02 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I strongly recommend spending some time with Chris Whealy's porous absorber calculator: http://www.whealy.com/acoustics/Porous.html
In fact a 2" panel with a 2" airspace can be soooo close to a 4" panel in terms of performance.
arnyk is offline
post #17 of 21 Old 04-03-2013, 09:23 PM
DonH50's Avatar
Liked: 1325
Thanks for the link, I shall do that.
But, even at 125 Hz and below? Yeah, I know, load the %$^%@# program... smile.gif I can type while resting during my practice sessions, but my focus is on my music, not the computer; I'd have to actually think to load and run it. I _will_ do it, however!
DonH50 is offline
post #18 of 21 Old 04-03-2013, 09:54 PM - Thread Starter
BB1111's Avatar
Quoted: 80 Post(s)
Liked: 32
IMO - Don
Have you compared with a diffuser and a thick absorber behind your Maggies?
BB1111 is offline
post #19 of 21 Old 04-03-2013, 10:15 PM
DonH50's Avatar
Liked: 1325
Yes, but long ago, mine and others (used to work for a dealer and helped install systems). Diffusors generally cost much more and must be very large to affect low frequencies. My present treatment is all absorption; I hope to gradually add diffusion, probably replacing some of the absorbers.
What do you want to know? Diffusion tends to help keep the more "spacious" sound many like while still breaking up higher-frequency cancellations. I have also heard a system with large (8' tall, roughly 4' wide and 4' deep) corner diffusors behind them, and they helped quite a bit. IME, diffusion does not provide as stable an image but tends to "open up" the sound more, and most people prefer the sound with diffusion rather than absorption. A room as dead as my current setup (the smallest and deadest room I have had them in, I think) provides excellent imaging and virtually no cancellation effects across the listening position, but all ambiance comes from the recording and not the room.
With the exception of the one system with massive diffusors, bass was better with absorbers behind the Maggies. The wavelengths are such that diffusors have to be huge, and even absorption at LF is difficult to achieve in practice. I have 10" corner traps and numerous 6" and 4" panels, all with 2" - 4" air gaps, along the front wall. A large room that allowed the Maggies to sit well out from the back wall is also less sensitive to that durn back wave.
All this applies to ESLs as well, natch.
Ethan can cover this in much greater depth than I, as can others who have posted here. My audio work and those pesky grad acoustics classes were long ago...
DonH50 is offline
post #20 of 21 Old 04-04-2013, 10:19 AM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
Originally Posted by arnyk View Post
...In fact a 2" panel with a 2" airspace can be soooo close to a 4" panel in terms of performance.
It's a cheap and effective way to test the hypothesis regarding bass response and listen to the result - that's the whole point of suggesting it.
fbov is offline
post #21 of 21 Old 04-04-2013, 10:57 AM
Quoted: 449 Post(s)
Liked: 153
Looks to me that 4" is about 2/3 of an octave deeper.
My Room
My Music
Jenzen Next
