Sudden PC > HDMI > Receiver problem - AVS Forum | Home Theater Discussions And Reviews
Old 04-01-2013, 05:46 PM - Thread Starter
csice's Avatar
I have been connecting my pc through hdmi to my receiver for about a year now with no issues, but now all of a sudden I get no audio. I always remember to switch the audio on my pc to the tv, but now I only get image and nothing has changed as far as I know. The only thing I can think of is the HDMI cable broke or something....can anyone give me some advice? This is very frustrating because I have no idea how to determine what the issue could be. Thank you.
csice is offline
Old 04-01-2013, 06:04 PM
amirm's Avatar
Quoted: 1334 Post(s)
Liked: 739
Audio is embedded in video in HDMI so it is not possible for it to break that way. Likely a software/setup change on the PC. Just confirming, the default/output sound device is HDMI in the control panel, yes? What happens if you just use windows media player and play some music? Does that work?
amirm is offline
Old 04-02-2013, 01:37 PM - Thread Starter
csice's Avatar
Yes, and no, it does not work. It used to play for a few seconds if would unplug the hdmi then plug it back in.
csice is offline
Old 04-02-2013, 02:12 PM
amirm's Avatar
Liked: 739
What shows up in the sound control panel while the HDMI cable is plugged in?
amirm is offline
Old 04-02-2013, 06:09 PM - Thread Starter
csice's Avatar
It does show the green audio bar on the left moving.
csice is offline
Old 04-02-2013, 08:01 PM
amirm's Avatar
Liked: 739
So the sound control panel shows the bar graph moving and no sound from the AVR? If so, have you confirmed that input on the AVR gets its audio from HDMI and not the other audio inputs?
amirm is offline
Old 04-02-2013, 08:02 PM
amirm's Avatar
Liked: 739
And again confirming that the bar graph that is moving is the HDMI audio and not some other audio device.
amirm is offline
Old 04-03-2013, 03:56 AM - Thread Starter
csice's Avatar
Yes, all of the inputs are correct and I do get a moving graph for the HDMI/TV option in audio section.
csice is offline
Old 04-04-2013, 10:13 PM - Thread Starter
csice's Avatar
Anyone else want to pitch in? This is literally driving me insane, I was using it all the time, now I have to watch everything at my desk.
csice is offline
Old 04-05-2013, 05:42 AM
Ratman's Avatar
Quoted: 1278 Post(s)
Liked: 1027
What happens if you run the HDMI from the PC to the directly? Does audio work?
Have you tried unplugging the power from receiver for a few minutes (hard power reset)?
Ratman is offline
Old 04-06-2013, 04:30 PM - Thread Starter
csice's Avatar
Before I attempt to get the cable to reach my tv, I can say that when I unplug then plug back in, my receiver says PCM and the sound works from the receiver for like three seconds and then it stops and reads decoder off on the receiver.
csice is offline
Old 04-06-2013, 06:16 PM
Kilian.ca's Avatar
Liked: 37
So far you still haven't clearly figured out which is at fault: PC, cable or AVR.
A quick Google search with 'decoder off' shows many Yamaha hits smile.gif, for a start:
http://faq.yamaha.com/us/en/article/audio-visual/av-receivers-amps/rx/rx-v367_black__u/4884/4196/
http://www.justanswer.com/electronics/5hb1d-yamaha-receiver-display-says-decoder-off.html
http://www.avsforum.com/t/1304312/yamaha-htr-5063-decoder-off
Audiosceptics accept audio trials using 25 people. A recent Oxford study with over 353,000 patient records from 639 separate clinical trials shows for every 1,000 people taking diclofenac or ibuprofen there would be 3 additional heart attacks, 4 more cases of heart failure and 1 death every year.
Kilian.ca is offline
Old 04-09-2013, 09:05 PM - Thread Starter
csice's Avatar
Well, I still can't seem to figure this out, anyone have any more suggestions?
csice is offline
Old 04-09-2013, 09:28 PM
amirm's Avatar
Liked: 739
Does this happen with the Windows Media player playing *music*?
amirm is offline
Old 04-10-2013, 02:56 AM
Kilian.ca's Avatar
Liked: 37
It's not hard to adopt a systematic approach.
Try another cable.
Try all the other HDMI inputs.
Try another HDMI source.
Try another AVR!
Old 04-15-2013, 06:29 PM - Thread Starter
csice's Avatar
Well, I have gotten a laptop and plugged that in and it worked, so it must be my pc even though nothing I am aware of changed. What should my next step be?
csice is offline
Old 04-15-2013, 08:57 PM
cel4145's Avatar
Quoted: 2657 Post(s)
Liked: 2987
Just a long shot, but you did try to rerun the configuration for the audio device in Windows? For whatever reason, my HTPC refuses to send out audio over HDMI sometimes. I go in, play couple of the the test tones, and then it works.
Living room HT: Energy RC-50, Ascend Sierra Horizon w/RAAL, Ascend Sierra 1, PSB Imagine XA | PSA V1500 and CHT SS 18.1 | Denon X4200W | modified Dayton SA1000
Other rooms: CBM-170 SE | SVS SB-1000 | Audio-GD NFB-11 | Parasound Zamp | JBL LSR305
Headphone & Portable AKG K7XX | NAD HP50 | AKG K550 | Soundmagic E50 & E80 | DX50 | E12 | X1
cel4145 is offline
Old 04-15-2013, 09:19 PM
stormwind13's Avatar
Quoted: 60 Post(s)
Liked: 96
AMD card? There are issues with catalyst control center incorrectly counting receiver hdmi inpots as DVI disabling the audio.
stormwind13 is offline
Old 04-15-2013, 10:02 PM - Thread Starter
csice's Avatar
I have an Asus eah6850 so yes AMD. And I do have catalyst.
csice is offline
Old 04-16-2013, 09:09 AM
Quoted: 60 Post(s)
Liked: 96
That's likely your problem. Downgrade the control center to 13.1, 12.2 and 3 are ok too I believe. There is also a registry edit fix too but I don't remember what it is anymore. Something about not allowing the card to go into standby mode.
Old 04-22-2013, 03:41 PM - Thread Starter
csice's Avatar
Thank you storm, that actually worked.
Now however, I have a different problem I don't think I can solve that I was hoping someone might have some suggestion to. I have my pc connected through hdmi to my receiver and I use clone mode. Now, when using my pc, the mouse can move indefinitely off the right side of the screen.
Edit: I guess it only does this when my tv is off...odd
csice is offline
Old 04-22-2013, 05:58 PM
Quoted: 60 Post(s)
Liked: 96
Your computer recognizes the receiver as another monitor therefore allowing the mouse to go into a second screen. There is no fix for that as far as I am aware.
Old 04-24-2013, 12:21 PM
scorrpio's Avatar
There is. Blasted HDMI 'smartness'. PC connected via HDMI to AVR to TV, and every time AVR was turned off or switched to different input, or TV was turned off, my display would reconfiger itself. Immensely frustrating.
The ONLY solution that did work for me was Gefen HDMI Detective Plus. This little box goes between PC and AVR and reports active HDMI connection and constant EDID to the PC no matter what is the state of downstream components. Now PC thinks AVR and TV are always on, and set to get input from PC.
scorrpio is offline
Old 05-01-2013, 05:03 PM - Thread Starter
csice's Avatar
Sorry to bring this back up, but I am having another issue. My mouse moves indefinitely off the right side of the screen when I have my tv off, but more importantly when my display is set to extended mode. This is important because I want it in duplicate, but it keep switching back to extended on its own. I can manually switch to clone mode when I want to use my tv, but sometime in between, it switches back unbeknownst to me. Does anyone have any idea on this one? It never used to switch automatically before I updated the catalyst.
csice is offline
