speakers for bar area/rec room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-02-2013, 07:49 PM - Thread Starter
dinosaur1's Avatar
I need some advice on what type of speakers and receiver to buy as well as placement. This is in our basement rec room. We love listening to music, but we also have a child so it doesn't need to be top of line or very loud. Something that is a better than a Bose tabletop speaker.
dinosaur1 is offline
post #2 of 9 Old 04-03-2013, 09:18 PM - Thread Starter
dinosaur1's Avatar
Ummm, hello?
post #3 of 9 Old 04-04-2013, 05:45 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What's your price range, more specifically?
I'd say that about $500 would be minimum, and that would be a low end AVR with a couple of good bookshelf speakers.
For starters, a pair of Infinity Primus P163s and a low end Denon AVR?
http://www.amazon.com/Infinity-Primus-Two-way-Bookshelf-Satellite/dp/B0045NCB32
or
http://www.amazon.com/Pioneer-SP-BS22-LR-Designed-Bookshelf-Loudspeakers/dp/B008NCD2LG/ref=cm_cr_pr_pb_t
http://www.accessories4less.com/make-a-store/item/ONKTXNR515/Onkyo-TX-NR515-7.2-Channel-Network-A/V-Receiver/1.html
Leaves you lots of room for expansion into a 2.1, 5.1 or larger system.
arnyk is offline
post #4 of 9 Old 04-05-2013, 10:37 PM - Thread Starter
dinosaur1's Avatar
or
That sounds pretty reasonable. How and where should I position the speakers?
post #5 of 9 Old 04-06-2013, 07:27 PM - Thread Starter
dinosaur1's Avatar
or
I was thinking about Bose speakers, but they are way too pricey....?
post #6 of 9 Old 04-07-2013, 03:24 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
One can do much, much better.
Arny gave good advice.
What's your max budget for AVR, speakers, disc player? I'm not well versed in AVRs, but there's some solid offerings in loudspeakers.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #7 of 9 Old 04-08-2013, 06:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
For starters, a pair of Infinity Primus P163s, or a competitive product from Pioneer, and a low end Denon AVR?
or
Bose appears to be at the weak end of the price/performance spectrum. If you want absolutely the physically smallest speaker for a given level of performance, they may have something for you.
Given your weak posting history to this thread you started, I get the feeling that you really don't know what you want, and don't even care that much.
arnyk is offline
post #8 of 9 Old 04-11-2013, 06:53 PM - Thread Starter
dinosaur1's Avatar
. I'm a busy person who also enjoys technology. How funny you mention that I'm not interested when its taking you a day to respond. Thanks anyway and as far as your rude comment.... There's no room for that here dude.
post #9 of 9 Old 04-11-2013, 06:54 PM - Thread Starter
dinosaur1's Avatar
300-400 bucks
