Speaker Selector Switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 04-16-2013, 12:15 PM - Thread Starter
Willyoung351's Avatar
Can anybody suggest a speaker selector switch for using one amplifier to switch between two pairs of speakers. I am concerned that the cheap ones on ebay will cause a loss in sound quality
Willyoung351 is offline
post #2 of 9 Old 04-16-2013, 12:20 PM - Thread Starter
post #3 of 9 Old 04-16-2013, 02:53 PM
MarkHotchkiss's Avatar
Liked: 85
Hi Will,
I don't think you need to worry about sound quality. A switch would have almost no impact on a speaker connection, unless you are pushing so much power that the switch can't handle it and burns-up.
You might have to worry about impedance. That switch will put the speakers in parallel if both are enabled at the same time. If both sets of speakers are 4 ohms, the resulting impedance will be 2 ohms, which some amps won't be able to handle. A few amps can't handle 4 ohms, so even two sets of 8 ohms speakers could over-tax the amp.
If you never enable both sets of speakers at the same time, then you never have to worry about it.
MarkHotchkiss is offline
post #4 of 9 Old 04-16-2013, 03:56 PM - Thread Starter
Thanks for your help I will go ahead and purchase one. Also do you know anything about the benefits of bi amping floorstanders? I cant say its something ive tried before but do you think it is worth it for my floorstanders AE120s?
post #5 of 9 Old 06-23-2013, 04:44 PM
Spaznik's Avatar
Originally Posted by MarkHotchkiss View Post
Hi Will,
Can you talk more about this when it comes to selectors that have impedance-matching protection circuitry? Like this one: http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10903&cs_id=1090305&p_id=8230&seq=1&format=2#description
It claims the following: This speaker selector allows you to connect up to eight stereo speaker zones. Each zone can be individually toggled on or off with the front panel switch. Built-in impedance-matching circuitry ensures that the overall impedance level to the amplifier does not drop below 5 Ohms, no matter how many speaker zones are selected or how many speakers are in each zone.
Is this safe to use?
Spaznik is offline
post #6 of 9 Old 06-24-2013, 07:32 PM
Liked: 85
Hi Spaznik,
I suspect that it is. I don't know how they do the protection, but it sounds like it directly addresses the concerns that I stated above.
post #7 of 9 Old 06-30-2013, 01:52 PM
Spaznik's Avatar
Hi Spaznik,
Thanks for the response. So far it seems to be working fine.
Spaznik is offline
post #8 of 9 Old 03-18-2014, 05:28 PM
tinsville's Avatar
Hello,
on this topic, I thought I would be safe matching up impedences between speakers and selector switch. Having read this thread I'm not so sure and would appreciate some advice. I've got this set-up:
1) Single outdoor speaker, 4 ohm, approx 100W
2) Pair of indoor speakers, 4-8 ohms, 15-100W
3) Amplifier, 4-8 ohm, 20W rating at 8 ohms
We use the indoor speakers for the tv, outdoor speaker is on the patio which may be used at the same time (on a sunny day)
I was thinking of getting this 2-way selector switch:-
http://www.amazon.co.uk/HQ-Speaker-Control-Connect-Speakers/dp/B000W1XMJS/ref=sr_1_1?ie=UTF8&qid=1395184346&sr=8-1&keywords=speaker+switch+with+protection
Having read the comments above, I wonder whether this one might be more suitable:-
http://www.amazon.co.uk/gp/product/B003GSVHD2/ref=pd_lpo_sbs_dp_ss_2?pf_rd_p=103612307&pf_rd_s=lpo-top-stripe&pf_rd_t=201&pf_rd_i=B000W1XMJS&pf_rd_m=A3P5ROKL5A1OLE&pf_rd_r=0EVESTVMEWGRETFY66FC
Which should I go for?
tinsville is offline
post #9 of 9 Old 03-21-2014, 11:16 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
I was checking back on this thread and noticed no one ever answered this question:
This is a highly contested subject and there was just a very good thread on it - to me it proved there was no real benefit under normal conditions - you can learn more about the subject than you can imagine in this thread:
http://www.avsforum.com/t/1492314/question-on-bi-amping
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
