Help!!! Technics SL-1210MK2 forgot to set from 110v to 220v - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-17-2013, 10:28 AM - Thread Starter
gxxrgehk's Avatar
Technics SL-1210MK2 forgot to set from 110v to 220v.
I turned on with 110v and a blue light flashed once.
Suddenly I remembered wrong voltage and switched off the power at once.
Since than I can't turn it on.
What can I do?
gxxrgehk is offline
post #2 of 8 Old 04-17-2013, 10:42 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What can I do?
Find a qualified service tech and pay him to do his thing.
arnyk is offline
post #3 of 8 Old 04-17-2013, 10:45 AM - Thread Starter
gxxrgehk's Avatar
It's there any internal fuse that blown up and need to replace?
gxxrgehk is offline
post #4 of 8 Old 04-17-2013, 02:54 PM
David Susilo's Avatar
Quoted: 612 Post(s)
Liked: 584
IIRC the unit doesn't have internal fuse, the transformer may be blown.
follow my A/V tweets @davidsusilo
ISF, THX, CEDIA, Control4 & HAA certified
Reviewer for TED & WifiHifi Magazines
my (yet to be completed) BD list
my home theatre
David Susilo is offline
post #5 of 8 Old 04-17-2013, 05:25 PM - Thread Starter
gxxrgehk's Avatar
On manual there is a fuse, right,
How can I access it and replace it?
technics_sl12xx_service_manual.pdf 2628k .pdf file
technics_sl12xx_service_manual_P.26.pdf 283k .pdf file
File Type: pdf technics_sl12xx_service_manual_P.26.pdf (283.1 KB, 91 views)
gxxrgehk is offline
post #6 of 8 Old 04-17-2013, 05:32 PM
Quoted: 612 Post(s)
Liked: 584
You should be able just to unscrew the bottom of the turntable and find those fuses on the daughter board closest to the voltage switch. See which one that's blown and just pull that one and replace it with another with the same value and fast-blow variety.
my home theatre
post #7 of 8 Old 04-17-2013, 11:47 PM
gxxrge's Avatar
gxxrge is offline
post #8 of 8 Old 04-18-2013, 09:59 AM - Thread Starter
gxxrgehk's Avatar
gxxrgehk is offline
