YPAO - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By bradman
  • 1 Post By crn3371
post #1 of 14 Old 04-22-2013, 06:15 AM - Thread Starter
clintsound's Avatar
Quick question:
What should the volume on my Yamaha be set on when setting up YPAO?
clintsound is offline
post #2 of 14 Old 04-22-2013, 06:51 AM
nodnerb's Avatar
It doesn't matter.
nodnerb is offline
post #3 of 14 Old 04-22-2013, 07:05 AM - Thread Starter
clintsound's Avatar
Thanks mate.
post #4 of 14 Old 06-10-2013, 09:15 AM
dude74's Avatar
Ok, so for YPAO I have "extra speaker assignment" set at none (choices are: zone 2, precence, and none), EQ Type set at front (choices are: flat, front, and natural). Is this correct? I'm only running 2.1 system right now. Want to make sure before I start the test.
Yamaha RX-V1065 receiver
Bowers & Wilkins 685 front speakers
SVS SB-1000 subwoofer
Marantz PMD350U CD/cassette player
Sony BDP-N460 Blu Ray player
Sony Bravia KDL-40V5100 flat screen TV
Wii game console
Roku 2XD internet streaming box
dude74 is offline
post #5 of 14 Old 06-10-2013, 01:47 PM - Thread Starter
clintsound's Avatar
Sounds right to me
post #6 of 14 Old 06-10-2013, 05:12 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
Might try setting eq to flat.
crn3371 is offline
post #7 of 14 Old 06-18-2013, 01:15 PM
Justin Sullins's Avatar
Liked: 32
Ran YPAO but measurements (distance) aren't exactly accurate. Would getting a tape-measure out and manually applying the correct distances have that much of an effect on the sound or should I leave the YPAO Distances?
Justin Sullins is offline
post #8 of 14 Old 06-21-2013, 04:05 AM
bradman's Avatar
Quoted: 17 Post(s)
Liked: 26
The distances set by YPAO are for room/delay correction so that all sounds arrive at the listening position at the same time.
They aren't meant to be the actual distances. The sub setting, in particular, will look "way off" but should be left alone
PlasmaPZ80U likes this.
bradman is offline
post #9 of 14 Old 06-21-2013, 09:23 AM
Liked: 32
Ok. I'll just leave it be. Thanks.
post #10 of 14 Old 06-21-2013, 11:16 AM
PlasmaPZ80U's Avatar
Quoted: 1969 Post(s)
Liked: 562
I'm glad I read this post. I was getting a reported distance of 15 ft for my SW when the tape measured showed 9 ft. Could you comment on how accurate YPAO is at determining the SW crossover (mine gets set to 80Hz) and the whole PEQ equalizer thing?
UN46EH6030 Calibration/Settings
Samsung UN46EH6030; Yamaha HTR-3066, SVS Prime Bookshelf Mains and Prime Center, Cambridge S20 Surrounds, Rythmik LV12R; PS4, Xbox One, Xfinity X1 (CI CXD01ANI)
PlasmaPZ80U is offline
post #11 of 14 Old 06-21-2013, 12:17 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
The crossover setting will depend on your mains. My fronts are pretty good down to about 40hz, so I've found that a 60hz crossover setting sounds better to me.
crn3371 is offline
post #12 of 14 Old 06-21-2013, 01:25 PM
Liked: 562
my mains and surrounds are the same, they are what comes with the YHT-399U HTiB
http://usa.yamaha.com/products/audio-visual/hometheater-systems/home-theater-package/yht-399/?mode=model
NS-AP2600_manual.pdf 254k .pdf file
post #13 of 14 Old 06-21-2013, 02:38 PM
Liked: 32
I had the same speakers, (NS-AP2600), but I somewhat upgraded to NS-C210 Center and NS-B210 Mains (Yamaha) and kept two of the NS-AP2600 Speakers for surrounds. YPAO set mine at 80Hz also as well as my new center and mains. I think they sound better at 80Hz, IMO.
post #14 of 14 Old 06-21-2013, 02:54 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
With those speakers, I'd try something higher than 80hz and see how it sounds. I would think 100hz, or 120 hz would be more appropriate.
crn3371 is offline
