Yamaha RXV-673 YPAO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-22-2013, 02:04 PM - Thread Starter
MindNoise's Avatar
Hi Folks,
After 6 months with RXV673 I finally ran YPAO! I originally set the receiver manually with a tape measure and sound meter. After running YPAO I find that it was quite accurate with all the settings I originally inputted. I just find the bass is a bit low for my standards. I read in the forum that some have "tweaked" their YPAO settings; how is this done? I can see the manual setting folder in the menu, is this where manual changes will take effect if I make any modifications to YPAO?
Thank you in advance for your help.
Jay
MindNoise is offline
post #2 of 4 Old 04-23-2013, 01:11 PM
nodnerb's Avatar
Yep, modify things in the manual setup. YPAO tends to set the sub quite low.
nodnerb is offline
post #3 of 4 Old 04-25-2013, 08:42 AM - Thread Starter
MindNoise's Avatar
Thanks Nodnerb.
Bass back up to where I like it. I may turn off the YPAO: Flat PEQ as well, haven't decided if I like these settings yet.
post #4 of 4 Old 04-25-2013, 09:29 AM
basshead81's Avatar
Quoted: 179 Post(s)
Liked: 5230
Originally Posted by MindNoise View Post
Thanks Nodnerb.
you can also manually set the peq which is a really nice feature. another nice option is being able to import one of the ypao eq's for a base, then make your own adjustments!
Getting Started with REW: A Step by Step Guide -->http://www.roomeqwizard.com/REWhelp.pdf
Mini DSP Tutorial by Neutro --> http://www.avsforum.com/forum/113-su...g-minidsp.html
basshead81 is offline
