Constant vs Variable [CBR vs VBR] - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-23-2013, 12:08 PM - Thread Starter
anonymust's Avatar
Ok I'm new to all things Audio and Audio conversions
But I have a .aiff file-formated audio file (which I ripped from a home DVD with Handbreak and I wanted to convert it to MP3.
I was going to use Adobe Audition and do the ...save as.... but them I'm asked if I want to use CBR or VBR?
I just want to convert the audio and keep the highest quality that uses less space.
When I use VBR the file is smaller than when i use CBR..
So what exactly is the difference?
anonymust is offline
post #2 of 5 Old 04-23-2013, 12:53 PM
volta's Avatar
For the highest quality, I would go with CBR. Constant Bit Rate means the bit rate is a constant for the whole song. I would recommend the highest setting (320 kbps). Variable means the bit rate changes (varies) throughout the song. This setting is best if you really want the smallest file and are concerned about space.
Still the difference is very minimal (sound wise) and you probably will not hear a difference. Unless you choose 160 kbps vs 320 kbps, then you could hear a difference.
If you aren't concerned with hard drive space, go with the CBR at 320 kbps. It will still be a small file and you will get the best possible lossy overall.
Hope this helps
volta is offline
post #3 of 5 Old 04-23-2013, 12:59 PM
Nethawk's Avatar
Liked: 118
If it's just one song, then I would choose CBR. If you are considering your entire collection then you might rather choose VBR for the savings on disk space, in particular mobile devices. As volta said, it's hard to say whether you'll hear a difference.
The answer to your next question is VBR -0 wink.gif This will provide the highest bitrate in the resulting file.
Nethawk is offline
post #4 of 5 Old 04-23-2013, 01:02 PM
ssh33's Avatar
Then use VBR
http://wiki.hydrogenaudio.org/index.php?title=LAME
Look at the section titled "understanding the bitrate settings." VBR > CBR
anonymust likes this.
ssh33 is offline
post #5 of 5 Old 04-24-2013, 12:38 PM - Thread Starter
anonymust's Avatar
Originally Posted by ssh33 View Post
Then use VBR
Perfect!
