4 In-Ceiling Speaker Placement in 21'x23' room? - AVS Forum | Home Theater Discussions And Reviews
Old 04-23-2013, 01:41 PM - Thread Starter
2digmedia's Avatar
Hi guys,
Thanks for reading my first post.
I'm looking for the ideal in-ceiling speaker placement for 4 speakers (2 stereo pairs) in a new construction, 21'x23' room. These speakers will be hooked up to a Sonos system and will play TV, music, etc. Home theater set up has been discussed but declined.
I asked Crutchfield to come up with an ideal placement, and they responded with this:
What are your thoughts on this? This seems a spaced out a little too much.
2dm
2digmedia is offline
Old 04-23-2013, 01:44 PM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
The ideal placement for in-ceiling speakers is to not put them in the ceiling! biggrin.gif
Now, if you don't care about sound quality and stereo imaging etc, and appearance is all that really matters, by all means have at it. Otherwise, this short article explains the best way to place speakers in a room:
How to set up a room
--Ethan
Ethan Winer is offline
Old 04-25-2013, 10:32 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
--Ethan
+1 what Ethan said, I'll give you real world example.
In my basement I have a dedicated HT with a decent rec room nearby.
I have a pool table there and wanted audio, I went with decent in-ceiling speakers from Paradigm.
My expectation was never HT quality sound quality nor iamging, basic background music for the occassional big sports party or music when the HT is off and just in the basement.
It does that, and only that. There is a very small sweet spot where you can get stereo imaging, but you need to be on the pool table!
Picture here shows me moving them because they were installed 3 years before the pool table.
If you do continue with the 4 in-ceiling speakers for your big room, at least lower your expectations for what they will deliver.
Even then, you may be dis-appointed.....
mtbdudex is offline
Old 04-25-2013, 11:13 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
All good advice.
Besides the inherently poor sound quality issues, you're entirely stuck from any movement down the road whatsoever.
Good luck, I hope this all works out for you. Oftentimes, individuals don't want to destroy the appearance of the room in which the want to enjoy music/TV/movies, etc. So they instead ruin the sound of the music/TV/movies, etc. Architects,...they love placing the TV above the fireplace,..they love placing speakers in the ceiling ... it looks good, until you turn it on.
Best of luck, at least you're asking questions, many don't even think to ask. So you're ahead of the curve.
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
Old 04-25-2013, 11:21 AM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2902
In that case, laying out the 4 in-ceiling speakers in the 4 corners of the room is fine for background music. In your drawing you have an L-shaped sectional, with listener positions facing the front wall and the right side wall. With this seating in mind, I would swap the left/right speaker positions in the back corners so that no matter which wall the listeners face, they will hear stereo.
Sanjay
sdurani is offline
