I am putting in 3 businesses in one building. Putting up 2 walls, to make one big space, 3. How should I wire them, to where they all could play the same music - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 04-29-2013, 08:15 AM - Thread Starter
thepiks's Avatar
As of now I have a NAD M15 pre amp. I am about to buy around 12 PSB CS 500.
I am looking for the best way to hook this up.
Can I run all these speakers off this 1 pre/pro? Or do I need to order a couple more?
I will likely be running the music off my spotify via iMac.
It is not a must that they all play the same music, I just thought it would be easiest, if it is not easiest, then I'm open to all different suggestions.
thank you in advance for your help!
thepiks is offline
post #2 of 4 Old 04-29-2013, 08:28 AM - Thread Starter
thepiks's Avatar
Also may be worth noting, that my NAD m15 has options for both 'stereo downmix' and 'mono downmix' which would be best to use? Would there be any audio degrading on going mono?
thepiks is offline
post #3 of 4 Old 04-29-2013, 08:53 AM - Thread Starter
thepiks's Avatar
is what I'm looking for a 'distributed audio system?' I have no need to page etc. But is this still what I need?
thepiks is offline
post #4 of 4 Old 04-29-2013, 09:53 AM - Thread Starter
thepiks's Avatar
For help, here is a layout of what I'm wanting got do in the building. All sq footage etc should be provided.
thepiks is offline
