GIK spot panel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 04-29-2013, 07:30 PM - Thread Starter
Bpack's Avatar
What does anyone know of this new panel from GIK?? It doesn't seem very substantial.
Bpack is offline
post #2 of 8 Old 04-30-2013, 02:15 PM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 767
Post a pict or link please, don't know what it looks like or specs.
Have you gone to GIK Facebook site or gearslutz ?
Sent from my 32GB iPhone4 using Tapatalk
mtbdudex is offline
post #3 of 8 Old 05-01-2013, 02:39 PM
someoledude's Avatar
Quoted: 14 Post(s)
They appear to be like the 242 panels but in skinnier or more squared up shapes. I could use some of the 12 x 48 x 2 " panels, but they are sold in boxes of 6 and I don't need that many. For specific applications and for making different colored and sized panel arrangements for aesthetic purposes.
someoledude is offline
post #4 of 8 Old 05-01-2013, 05:56 PM - Thread Starter
Bpack's Avatar
That's what I was thinking but they only seem to be a couple of inches thick. I mean, everyone at GIK, and all other companies, say the thicker and larger the surface area the better. So I understand and welcome the different shapes but not at a lesser performance. Why not make the 242 or 244 in some different shapes??
Bpack is offline
post #5 of 8 Old 05-01-2013, 07:43 PM
CruelInventions's Avatar
Quoted: 606 Post(s)
Liked: 746
Maybe that's the eventual plan. Expand with the 4" versions after getting these up and running, see how sales go, reassess package sizes, etc.
CruelInventions is online now
post #6 of 8 Old 05-07-2013, 07:52 AM
myfipie's Avatar
Quoted: 71 Post(s)
Liked: 72
Hey guys,
The Spot panels is built with only a 2" profile and does come in 3 standard sizes. And yes we do sell them by the box to maximize shipping for the customer. If you do need less then what is in a box you can email use to price out shipping for you.
Also we can custom make the 242 and the 244 but there is a up charge for this. The 242 and th 244 are make totally different then the spot panel. The spot panel is more what you see on other sites that are just a framed up panel vs the 242/244 that has a 2 frame system. It maximizes the absorption with sound coming in from the sides and has a built in air gap.
Glenn
GIK Acoustics
Glenn Kuras
GIK Acoustics
http://www.gikacoustics.com
myfipie is offline
post #7 of 8 Old 05-07-2013, 10:31 AM
GIK Acoustics's Avatar
Quoted: 16 Post(s)
Liked: 31
Hi Bpack,
The Spot Panel was introduced more for commercial customers. They are a thin profile panel usually used to reduce reverberation and not really for small rooms dominated by modes. For a typical room, we usually suggest starting with the 242s as the thinnest treatment since the built in air gap allows for better absorption at a lower frequency and the frame system allows a wider variety of mounting options.
Alexander Reynolds
GIK Acoustics
GIK Acoustics is offline
post #8 of 8 Old 05-07-2013, 10:32 AM
Quoted: 16 Post(s)
Liked: 31
We could do a smaller order if you contact us directly. We can also custom size our 244s or 242s to be a different size if necessary as well.
Edit, also just to clarify Glenn's statement earlier:
He's saying the 242s and 244s are what maximize the absorption by absorbing sound coming from the side with the built in air gap here - not the Spot Panel. Worded kinda funny so I figured I'd clarify.
The Spot Panels just have a frame that wraps around the edge of the panel, so you don't get any side absorption nor a built in air gap with them. They're primarily for reducing reverberation @ about 350 Hz and above.
Alexander Reynolds
GIK Acoustics
