7.1 Question.... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 05-02-2013, 07:38 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
Soi just set up my 7.1 with the extra speakers going into the front high area. I have a Marantz SR7007
Thought id test it out, got test signals. Great lets put a movie on.
I put Avengers in (thought this would be a great movie to check) and im getting zero sound out of the front high speakers. Anyone know why?
amairphoto is offline
post #2 of 13 Old 05-02-2013, 07:47 PM
Skylinestar's Avatar
Quoted: 1046 Post(s)
Liked: 182
Did you switch on Dolby ProLogic IIz?
Skylinestar is online now
post #3 of 13 Old 05-02-2013, 07:53 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
ahh thought it would automatically realize i would want that setting. All good now! thnk you!
post #4 of 13 Old 05-02-2013, 07:55 PM
llkindt's Avatar
Quoted: 23 Post(s)
If the Marantz is selecting Dolby True HD, with a bluray disc, then no you will not get the height speakers to play. I believe you need to select something like Pro Logic IIZ. I had the same problem with my Onkyo 1007. It wouldn't play wides or height with a blu ray disc because I had selected Dolby True HD as the prefered sound field on blu ray. I could be wrong, but it wouldnt hurt to try changing the sound processing to see what happens. Oops! someone beat me to it.
Cheers
llkindt is offline
post #5 of 13 Old 05-02-2013, 07:55 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
I chose True HD + PLIIz
there is another setting
True HD + A-DSX (height)
is that any good? compared to the PLIIz
post #6 of 13 Old 05-02-2013, 07:59 PM
llkindt's Avatar
Quoted: 23 Post(s)
Cant really give you advise one that one because the Onkyo doesnt offer it. Give them both a shot and see what you preffer. Glad you got your problem resolved. Now get off the forum and enjoy your new set up!biggrin.gif
Cheers
llkindt is offline
post #7 of 13 Old 05-02-2013, 08:28 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
i love it, definitely feels like im now surrounded in sound.
post #8 of 13 Old 05-02-2013, 08:32 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
So i came across this site
http://www.blu-raystats.com/Stats/Stats.php
it lets you know which are 7.1 and which arent. I didnt see Avengers on there for 7.1, but i do see Finding Nemo, I now have Dolby True HD + PLIIz set but would i be better just using True HD for a movie like Finding Nemo that does support 7.1 and not the PLIIz setting?
post #9 of 13 Old 05-02-2013, 10:16 PM
sdurani's Avatar
Quoted: 4479 Post(s)
Liked: 2904
Listen to them both and decide which you prefer. Just so you know how they work: PLIIz extracts ambience from the surround channels to feed the height speakers; by comparison, DSX generates early reflections (that weren't in the soundtrack) to feed the heights.
The list of movies with 7.1 channels are all 5.1 + 2 rears; none of those 7.1 soundtracks are 5.1 + 2 heights. The only way you'll get all 7 of your speakers to light up is to use PLIIz processing.
Sanjay
sdurani is offline
post #10 of 13 Old 05-04-2013, 09:10 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
Could you elaborate on this please, i dont quite understand how it generates something that is not there....
post #11 of 13 Old 05-04-2013, 11:40 PM
sdurani's Avatar
Liked: 2904
Ever play with the reverb knob on a karaoke machine? That reverb wasn't in the recording (otherwise you wouldn't be able to adjust it).
Same basic concept, more sophisticated processing, and you can simulate a few of the early reflections from a concert hall or jazz club. And that's essentially what Yamaha DSP and Audyssey DSX do: room simulation (give you the impression of being in a larger space).
You can hear it for yourself without extra speakers IF your receiver has any of those Hall or Stadium or Club modes.
Sanjay
sdurani is offline
post #12 of 13 Old 05-04-2013, 11:43 PM - Thread Starter
amairphoto's Avatar
Quoted: 44 Post(s)
ahi see. I think i prefer the PLIIz setting, the DSX one sounds a bit echoey.
post #13 of 13 Old 05-04-2013, 11:52 PM
sdurani's Avatar
Liked: 2904
OK, seems you can already tell the difference between extracting ambience and generating ambience.
Sanjay
sdurani is offline
