7.1 speaker placement- new construction - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-04-2013, 03:30 PM - Thread Starter
cratch's Avatar
Hello,
We're building a new home- just broke ground, so we got a ways to go! I've convinced the wife that we need to go 7.1 SS.
We're going with in-wall speakers- I was hoping to use my Polk Audio cubes, but that got nixed wink.gif
Below is my setup. Is this OK?
My Setup:
Sony XBR65X850D 65-Inch 4K Ultra HD Smart TV
Denon AVR-S900W
Harmony Hub Elite remote
7.1 speakers: (combination of Polk Audio and ceiling speakers)
cratch is offline
post #2 of 7 Old 05-04-2013, 10:57 PM
sdurani's Avatar
Quoted: 5140 Post(s)
Liked: 3621
More than OK. Those speaker angles look ideal. Should sound great when done.
Sanjay
sdurani is offline
post #3 of 7 Old 05-05-2013, 12:49 PM - Thread Starter
cratch's Avatar
Thanks for your input! As for the angles- these are going to be in-wall, not cubes, so I'm not going to be able to point these speakers like I'd want to.
How good are the best in wall speakers at Monoprice? I'm all about cheap HDMI cables, but speakers scare me. I don't want to invest in this setup only to put crap paper cone speakers. Does Monoprice have high quality speakers?
Thanks!!!
My Setup:
Denon AVR-S900W
cratch is offline
post #4 of 7 Old 05-05-2013, 02:46 PM
sdurani's Avatar
Liked: 3621
Never heard Monoprice speakers, so I can't tell you how good the are. But some of their models have pivoting tweeters that you can point towards the listening area.
Then don't buy the Monoprice in-walls with the "crap paper cone speakers" and instead buy the ones with the kevlar woofers.
Sanjay
sdurani is offline
post #5 of 7 Old 05-08-2013, 04:28 PM
underminded999's Avatar
Quoted: 29 Post(s)
I used these for my back surrounds.
These for the sides.
I've been pleased with them.
However, for LCR, I recommend full range speakers. Sides and rears are for ambient noises and directional cues. LCR's carry most dialog for movies, and present the front soundstage for music.
underminded999 is offline
post #6 of 7 Old 05-08-2013, 05:14 PM - Thread Starter
cratch's Avatar
@underminded999 thanks for your input! Just to be clear- are those speakers in-wall or in-ceiling?
Both of those are labeled as in-ceiling... I've wondered if you could use either in the wall...
My Setup:
Denon AVR-S900W
cratch is offline
post #7 of 7 Old 05-08-2013, 05:51 PM
Quoted: 29 Post(s)
They are in-ceiling, but it doesn't matter, they can be used in-wall, too.
I cut the box that they came pact in, in half. Since our attic has blown in insulation, I put 1/2 of each box over the back of the speaker and then piled the insulation on and around them.
In-walls & in-ceilings don't know if they will have insulation around them, so they work with any kind of insulation, or lack there of.
