Speaker Wire Length - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-19-2013, 08:59 AM - Thread Starter
jaums's Avatar
I have a Bose Acoustimass-7, with 3 cube arrays & an accoustimass bass module.
It came with 6 20 foot cables, 3 that connect from the my Sony receiver to the bass module & 1 from the bass module to each of the 3 cubes.
I have had the system for quite a while and, although I didn't need 20 feet of cable for each of he connections, I didn't cut it in case I needed it in the future.
Now that I'm doing some rearranging for a new TV I'm wondering if having all this extra wire in a pile hidden behind books on the shelf is having a significant affect on my audio. I could cut the wires to a more reasonable length.
It's fairly heavy wire--similar to lamp cord, so probably my spaghetti pile of wire would not be a problem?
Jaums
jaums is offline
post #2 of 4 Old 05-19-2013, 09:16 AM
A9X-308's Avatar
Quoted: 1280 Post(s)
Liked: 951
No.
A9X-308 is offline
post #3 of 4 Old 05-19-2013, 09:31 AM
Ivan Beaver's Avatar
Liked: 57
It is far better to "have it in a pile" rather than neatly tied up in loops.
The "pretty" loops can (if everything lines up properly) can cause some issues-from hum pickup to HF loss etc.
But the extra length is not going to make enough of a difference that you would notice-so just "pile it up" out of the way.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #4 of 4 Old 05-19-2013, 11:56 AM
SAM64's Avatar
Liked: 78
[The "pretty" loops can (if everything lines up properly) can cause some issues-from hum pickup to HF loss etc.
Not really, It's virtually impossible to induce hum into such a low impedance circuit...otherwise every speaker, which has a long coil of wire as a voice coil, would hum.
A coil of parallel wires, with current flowing in opposite directions, doesn't make a very good inductor either.
SAM64 is offline
