HDMI Audio Voltage Spec - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-20-2013, 12:04 PM - Thread Starter
GGA
GGA's Avatar
Quoted: 198 Post(s)
Liked: 39
From what I can research AES/EBU has an output voltage that ranges between 2V and 7V with a maximum of 7V and S/PDIF has an output voltage of 0.5V with a maximum of 0.6V (all peak to peak).
Does anyone know what is the output voltage of HDMI audio from a BD? Could not find any specs with google. Just curious.
GGA is offline
post #2 of 6 Old 05-20-2013, 12:55 PM
DonH50's Avatar
Quoted: 1792 Post(s)
Liked: 1325
You mean the digital TMDS signal? For HDMI 1.3, termination is to 3.3 V and swing is 400 to 600 mV single-ended into 50 ohms (800 to 1200 mV into 100 ohms differential). The 1.4 spec is not available as a free download.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #3 of 6 Old 05-20-2013, 12:59 PM
SAM64's Avatar
Liked: 78
Audio is interleaved with video and control signals, there isn't really an HDMI audio signal.
SAM64 is offline
post #4 of 6 Old 05-20-2013, 02:30 PM - Thread Starter
GGA
GGA's Avatar
Quoted: 198 Post(s)
Liked: 39
Originally Posted by DonH50 View Post
You mean the digital TMDS signal? For HDMI 1.3, termination is to 3.3 V and swing is 400 to 600 mV single-ended into 50 ohms (800 to 1200 mV into 100 ohms differenital). The 1.4 spec is not available as a free download.
Thanks. Very helpful.
I thought all the TMDS signals are balanced. What would be an example of a single ended HDMI termination?
GGA is offline
post #5 of 6 Old 05-20-2013, 02:30 PM
DonH50's Avatar
Liked: 1325
@SAM64: Isn't ARC on its own pair? Don't really know, not an HDMI guru or even all that knowledgeable, just curious. I thought the OP might mean ARC at first then realized it was (probably) the serial digital interface signals.
DonH50 is offline
post #6 of 6 Old 05-20-2013, 02:32 PM
DonH50's Avatar
Liked: 1325
They are balanced but the spec provides SE and diff levels. That is typical with differential signaling as you must also specify the absolute range the transceivers must abide.
In this case, there are a pair of 50-ohms R pulled to 3.3 V that present a 100-ohm differential impedance.
DonH50 is offline
