Sub wiring set up. - AVS Forum | Home Theater Discussions And Reviews
Old 05-21-2013, 09:53 PM - Thread Starter
Luke E's Avatar
Gday all,
I remember reading on hear that when connecting a SW its best to use a Y junction and connect the RCA to both positive and negative jacks in the back of the SW.
Do I remember correctly?
And is this true or false?
Thoughts gentlemen.
Its a Denon 2312 with a Klipsch SW450
Luke E is offline
Old 05-21-2013, 10:07 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4775
I think in one of the Klipsch RW12d threads someone said (Bill F?) that there was a bit more gain in using both L/R inputs, even with a y splitter. The subs with a specific LFE input for avr management (sometimes just one of the L/R inputs), I would just use that LFE input alone and let my avr do the managing. I assume the L/R inputs on a sub are for sources that may be stereo to allow the sub to sum them for mono output.
lovinthehd is offline
Old 05-23-2013, 12:22 PM
fbov's Avatar
Quoted: 262 Post(s)
Liked: 150
The answer is, It depends...
That's true for my OAudio plate amps; louder output with both L & R channels fed, even through a splitter. However, this amp has a crossover-disabled switch in place of a dedicated LFE input.
However, your Klipsch is designed with a) L/R inputs when using the sub's crossover and b) a single LFE input when bypassing the sub's circuit and using the AVR for bass management.
Use the single LFE input, connected to your AVR's Sub Out.
Have fun,
Frank
fbov is offline
Old 05-23-2013, 01:28 PM
lovinthehd's Avatar
Liked: 4775
Have fun,
Frank
Frank, have you seen one of these? There's no dedicated LFE input on the amp panel....altho the "shared" manual for the model indicates there is one.
