AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Audio Theory, Setup, and Chat (http://www.avsforum.com/forum/91-audio-theory-setup-chat/)
-   -   Corner Entertainment Center Set-up (http://www.avsforum.com/forum/91-audio-theory-setup-chat/1474166-corner-entertainment-center-set-up.html)
zoomdaddy67 05-24-2013 02:19 PM
2 part question:
1) Looking for suggestions on speaker placement. The wife just bought new furniture for living room and entertainment center is now in a corner. I realize this is not great sonically, but unless I want to sit in the floor, it's what I got. Room is 13 x 14, furniture is in an L shape on walls opposite. I have about 3 feet on either side of E.C. for mains before I get into doorway and fireplace. Probably same amount of room from ends of couches to walls. Never tried surround with mains in corner before, so looking for advice. AVR can go 5.1 or 7.1
2) A local guy is selling his Polk setup, (4) RT24i and (1) CS245i, for $150. Anybody think this would be a good setup for my room arrangement?
Ethan Winer 05-25-2013 10:34 AM
This should help:
How to set up a room
I'll let others comment on those loudspeakers.
--Ethan
Wayne A. Pflughaupt 05-26-2013 10:48 AM
Unfortunately corner arrangement seldom get good results. Here’s why.
Wayne A. Pflughaupt
Espo77 05-27-2013 08:58 AM
Wayne A. Pflughaupt
??? as to the statement "place the left and right speakers as far apart as possible" ???
Espo77 05-27-2013 09:03 AM
2 part question:
Do not panic. Corner placement can and will sound just fine. One sonic advantage with corner placement is the absence of early side wall reflections, which is a good thing.
Ethan Winer 05-27-2013 11:28 AM
Yes, though the corner that's now behind you focuses all the sound back to your ears. So a corner can work, but it's best if large areas of the two walls behind you are treated with absorption (or diffusion).
--Ethan
GIEGAR 05-28-2013 05:40 PM
+1 Espo77. That's the big one!
--Ethan
Hi Ethan
How much of a concern is the reflection out of the back corner? Wouldn't it be delayed and attenuated in level somewhat due to bouncing of two walls to get back to the listener? Just curious... smile.gif
__________________________________________________________________________________________________________________
I must admit that I'm in love with the idea of "doing it on the diagonal" since reading this from Floyd Toole:
Now, I would not hesitate to deliberately design a room in this configuration.
source: http://www.harman.com/EN-US/OurCompany/Innovation/Documents/White%20Papers/LoudspeakersandRoomsPt1.pdf
Apart from those already mentioned, advantages include:
  • Subs placed mid-wall are almost flanking the mains
  • Because the side surrounds are a long way from the listeners, monopoles will be fine for movies and music (the mono/bi/di debate is over!)
  • Rear channel speakers can also be a long way from the listeners, particularly in a THX (narrow) setup
  • Works very nicely in the "almost square" room (like the OP's)
  • May be possible to have more "front row" seats, placed in a wide arc
The only other disadvantage I can think of (and it's not related sonics) is the increased "dead space" behind the screen is it gets larger.
Zoomdaddy: Can you talk your wife into pulling the new L shaped couch out of the corner 2 or 3 feet? Put a pot plant in the back corner or something? biggrin.gif
Ethan Winer 05-29-2013 11:14 AM
Those reflections are extremely strong. The entire rear of the room is now a giant dish antenna for audio frequencies. It does avoid side-wall reflections, but those are easily tamed with a few absorber panels. Taming the rear of the room requires more treatment.
--Ethan
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
