surround speaker placement - AVS Forum | Home Theater Discussions And Reviews
Old 05-25-2013, 09:56 AM - Thread Starter
redf4rr's Avatar
I have my surrounds behind me in the ceiling. They are in the corners of the room. I heard they should really be 90 or 110 degrees from u. I have a wall to mount to on the rihht, but a opening to the left. My ? Is can I mount them at different heights? The place on the left would be about 7-8' cause the opening and I could put up to 7' on the wall side. What are your guys oppions?
redf4rr is offline
Old 05-25-2013, 10:25 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Ideally you want them at the same elevation. Can you mount the left to the side of the opening? But being a foot difference might not make too much of a difference in the sound.
In any case, using on-wall speakers or in-wall will be a big improvement to the sound over the in-ceilings.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
Old 05-25-2013, 10:28 AM
Ethan Winer's Avatar
Quoted: 264 Post(s)
Liked: 359
Ideally you'll replace the speakers in the ceiling with normal "box" type speakers placed at the appropriate angle and height. This explains exactly what you need to know:
How to set up a room
--Ethan
Ethan Winer is offline
Old 05-25-2013, 10:39 AM - Thread Starter
redf4rr's Avatar
The speakers are normal speakers from JBL surround sound out of a box. I just used the brackets and mounted them to the ceiling. The opening on the left go 3/4 of the room. The only place would be about it about 7'6" above the opening. My room is 13' wide and I figured I would tilt the speakers downward towards the sitting area. Will I get better results with them beside me or mounted to the ceiling behind me about a 45 degree angle from listening position?
redf4rr is offline
Old 05-26-2013, 11:51 AM
Quoted: 264 Post(s)
Liked: 359
Great, then it's easy to take them down and place them as shown in the article I linked above.
--Ethan
Old 05-26-2013, 12:25 PM - Thread Starter
redf4rr's Avatar
I moved them to about 100 degrees besides me and what a difference! I now need to get a rear surround speaker.
Ethan Winer likes this.
redf4rr is offline
