Crossover Settings - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-04-2013, 10:11 AM - Thread Starter
Skytrooper's Avatar
Quoted: 222 Post(s)
Liked: 144
My Sunfire Sub is set at 80 HZ. My fronts are rated down to 54 HZ, Center 65 HZ, 4 in wall surrounds 58 Hz.
All I want to know is do I set all the other speakers to 80 HZ or closer to their cutoff freqs. I am having trouble getting these settings to register in my thick skull.
(LCD - Sony KDL -52 XBR4) (Receiver - Yamaha RX-A1040)(Blu Ray - Oppo BDP-83) (PS3)( Comcast X1) Speakers (L & R - Paradigm Studio 20) (Center -Paradigm CC-470) (Surrounds & Back Surrounds - Paradigm SA-15R in walls) (Subwoofer 1 - Sunfire HRS-12) (Subwoofer 2 - Paradigm PW-2100)
Skytrooper is offline
post #2 of 5 Old 06-07-2013, 06:33 AM
nodnerb's Avatar
Well, you usually wouldn't set the sub itself at 80HZ. You would set it at full range and let the avr handle the crossover. If your sub is crossed over at 80 though, I would also cross over the speakers at 80. The sub will handle the low frequencies better than your mains, after all, that's what it's made for. Plus, letting the sub handle the lower frequencies frees up some amp power and lets your other speakers play the mids and highs cleaner.
nodnerb is offline
post #3 of 5 Old 06-08-2013, 09:39 AM - Thread Starter
Skytrooper's Avatar
Quoted: 222 Post(s)
Liked: 144
nodnerd, thanks for the reply. My sub control is set at full range and the AVR does the crossing. So the way I finally got this to sink into my thick head is everything 80 HZ and below goes to the sub and 80 HZ and above goes to the rest of my speakers. Thanks again.
post #4 of 5 Old 06-09-2013, 11:32 AM
dazkyl's Avatar
Quoted: 22 Post(s)
Turn the crossover/frequency on the back of the sub to off or at its maximum setting so that you let the AVR handle the crossover. Then put 80hz crossover for everything in the AVR with small setting for each speaker.
dazkyl is offline
post #5 of 5 Old 06-09-2013, 11:42 AM - Thread Starter
Skytrooper's Avatar
Quoted: 222 Post(s)
Liked: 144
thanks dazkyl, thats what I already have done.
