wrong - AVS Forum | Home Theater Discussions And Reviews
View Poll Results: Is there a difference in sound between XLR balanced cables
Y or N 0 0%
y 0 0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
post #1 of 6 Old 06-08-2013, 06:50 PM - Thread Starter
kiwi2000's Avatar
Quoted: 13 Post(s)
wrong again
kiwi2000 is offline
post #2 of 6 Old 06-09-2013, 07:30 AM
commsysman's Avatar
Quoted: 964 Post(s)
Liked: 521
A poll makes no sense, because the difference is a technical issue and every technician and engineer knows the difference.
As any sound engineer knows, the signal-to-noise ratio of a balanced cable is 10,000 times better than is possible with unbalanced cables. There is no question that balanced cables are far superior.
In professional recording venues, the unbalanced cable(RCA) is considered unacceptable and highly compromised because of its poor performance characteristics and inadequate shielding. They are absolutely never used. The unbalanced cable is inherently deficient by its fundamental design.
Balanced cables SHOULD be standard practice in home audio, but the larger connectors pose a design problem in packaging the home equipment (plus balanced circuits cost more).
It is not uncommon to use a balanced (XLR) cable 100 feet long, or longer, to connect a microphone to a mixing console when recording professionally.
Despite the very small signal of the microphone, this will give an essentially noise-free signal every time, with no "special" cabling required. Balanced cables are also immune to interference and hum from AC power cords and sources of RF in the environment; unbalanced cables are poorly shielded and problems often occur.
The unbalanced cable MAY give acceptable performance some of the time, depending on its length and the equipment it is connected to, and the environment where it is placed; or it MAY NOT.
The balanced cable gives you perfect performance EVERY TIME, in EVERY SITUATION, regardless of its length or brand name. There is no difference in performance between one cable and another.
commsysman is offline
post #3 of 6 Old 06-09-2013, 04:57 PM
beaveav's Avatar
Quoted: 525 Post(s)
Liked: 666
^Nice rant, but you missed the point of his question. He didn't ask whether balanced cables are better than unbalanced; he asked if there are differences in sound quality from one balanced cable to another. rolleyes.gif
Semi-retired Technology Insider.
Insist on Quality Posting.
beaveav is offline
post #4 of 6 Old 06-09-2013, 05:57 PM
Speedskater's Avatar
Quoted: 20 Post(s)
There are measurable differences between balanced interconnects in worst case conditions. It's doubtful that your home listening is worst case.
Common-Mode to Differential-Mode Conversion in Shielded Twisted-Pair Cables
(Shield-Current-Induced Noise)
Jim Brown1 and Bill Whitlock2
1Audio Systems Group, Inc. Chicago, IL, 60640, USA
jim@audiosystemsgroup.com
2Jensen Transformers, Inc., Van Nuys, CA, USA 91406
This paper was presented at the 114th AES Convention in Amsterdam, March, 2003. You can search the
complete AES Electronic Library at http://www.aes.org/e-lib/ This paper is available as Preprint 5747.
http://www.audiosystemsgroup.com/AES-SCIN-ASGWeb.pdf
Kevin
Speedskater is offline
post #5 of 6 Old 06-09-2013, 06:47 PM
bo130's Avatar
Liked: 77
How much of this is audible, even worst-case?
bo130 is offline
post #6 of 6 Old 06-18-2013, 06:38 PM
Quoted: 20 Post(s)
Well the wost cases would be in pro-audio or broadcasting where 300 foot cables are common. What the poorer cable would pick up is interference noise which is never pleasant.
Kevin
