Help! 3 Pin Phoenix Type Connectors? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-11-2013, 07:56 AM - Thread Starter
gravykid's Avatar
I suspect my initial post was a bit meaty, so perhaps I'll just distill it down to one question:
The amp I'm looking at - the Crown CT875 8-channel amplifier, 75watt per channel - has 3 pin Phoenix type connectors for the inputs. I've never used these before. I'm looking at connecting in 5 Apple Airport Express', which from what I can tell use a Mini-Stereo connector. A bit of Google-ing led me to the cable I think I would need http://www.onyougo.com/revolabs-35mm-balanced-male-connector-to-3-pin-mini-phoenix-connector-audiovideo-cables_pi1760550
Is this all I need for connectors?
Many thanks!
gravykid is offline
post #2 of 7 Old 06-11-2013, 09:31 AM
SAM64's Avatar
Liked: 78
The amp has balanced inputs, the airport express has unbalanced stereo outputs. You'd be feeding left and right to the differential inputs of each amplifier....the output would be the difference, L - R.
SAM64 is offline
post #3 of 7 Old 06-11-2013, 12:44 PM - Thread Starter
gravykid's Avatar
Thanks for getting back to me so quickly. As I'm a bit of a noob when it comes to balanced/differential inputs, is that a yes? Am I ok with just the proper cable and plugging the airport express directly into the amp?
gravykid is offline
post #4 of 7 Old 06-11-2013, 12:57 PM
SAM64's Avatar
Liked: 78
no.
Are you'll need to combine the two channels out of the airport, then connect the hot to the + input on the amp and the ground to ground, leave the - input floating.
SAM64 is offline
post #5 of 7 Old 06-11-2013, 06:52 PM
Wayne A. Pflughaupt's Avatar
Quoted: 88 Post(s)
Liked: 67
What you need is a 3.5 mm headphone “y” splitter cable. Cut off both ends of the “y” and strip back the insulation. Connect the two “y” cable center conductors to the (+) terminals of two amplifier channels, and the cable’s shield to the (-) terminals. Connect a jumper from the (-) terminals to the ground terminal.
Wayne A. Pflughaupt
Equipment List
"A nice mid-fi system," according to an audiophile acquaintance.
Reviews and Tech Articles
Wayne A. Pflughaupt is offline
post #6 of 7 Old 06-12-2013, 04:58 AM
SAM64's Avatar
Liked: 78
Do you want stereo or mono?
No need to short the - input to ground.
SAM64 is offline
post #7 of 7 Old 06-12-2013, 07:12 AM - Thread Starter
gravykid's Avatar
I have 2 speakers per zone, and I would prefer stereo out of each speaker, but could live with mono as they are close by and are just for background music...
gravykid is offline
