Mixing Speaker Wire OK? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-20-2013, 09:38 PM - Thread Starter
mijotter's Avatar
Liked: 59
I bought 12g speaker wire from monoprice - 100ft roll. Problem is, I don't have enough speaker wire, my calculations were off. I really need this done this weekend so ordering online is not an option. Is it ok to mix brands of speaker wire so long as it is the same gauge?
mijotter is offline
post #2 of 6 Old 06-20-2013, 10:03 PM
Colm's Avatar
Liked: 94
No problem.
Colm is offline
post #3 of 6 Old 06-20-2013, 10:29 PM
olyteddy's Avatar
Quoted: 524 Post(s)
Liked: 913
Just don't splice it inside a wall.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #4 of 6 Old 06-20-2013, 11:56 PM - Thread Starter
mijotter's Avatar
Liked: 59
Thank you much guys! Is there a particular brand of speaker wire I should avoid and favor from, say, a Home Depot for example?
mijotter is offline
post #5 of 6 Old 06-21-2013, 12:16 PM
Colm's Avatar
Liked: 94
If it is going in the wall, it needs to be architectural cable with a CL2 or CL3 rating. You may have to order it.
Colm is offline
post #6 of 6 Old 06-21-2013, 12:19 PM
DonH50's Avatar
Quoted: 1806 Post(s)
Liked: 1346
Just get some 12g stranded power cable, they should have in-wall grade in stock.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
