I have an (approximate) 18 x 12 living room and don't know where to start - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 06-24-2013, 11:36 AM - Thread Starter
FamousRealName's Avatar
Hey all,
I know there's blanket info out there to point me in the right direction, but I'm hoping someone is bored and knowledgeable enough to give me some firm info. I have an 18 x 12 living room with about 9 feet of space between my sitting spot and the 40" Toshiba Regza that I'm riding till its death. I'm currently using a Yamaha YAS-101 soundbar and pretty disappointed with it. Oh, it's also a hardwood floor, if that matters?
I made a diagram of my living room for a visual aid:
Right now, I'm leaning toward a Denon receiver with Polk Audio 5.1 speakers. But that's me basing my opinion mostly on brand recognition. I am, by no means, a convinced buyer, so please -- let the pendulum swing with more opinions and info. At the moment, I'm thinking 5 speakers may be overkill in my living room. (I also hate the idea of running wires along the molding.) Would a 3.1 work? The thing I want most is to be consumed by bass.
Thanks for any help, folks. Looking forward to learning more around here.
FamousRealName is offline
post #2 of 8 Old 06-24-2013, 04:43 PM
commsysman's Avatar
Quoted: 1080 Post(s)
Liked: 569
Soundbars ARE rather poor in most cases.
I suggest the following:
Get a pair of Pioneer BS-22 speakers from Amazon for around $100.
These are SO much better than any other speaker you can get for under $250 that it makes them a steal.
Then get a Onkyo TX-8255 receiver for around $140, and you will have some very nice sound.
Does your old TV have analog audio outputs, or just a digital output?
If it has only a digital output, you will need to get a digital-to-analog converter, which only costs around $20 from Amazon.
FamousRealName likes this.
commsysman is offline
post #3 of 8 Old 06-25-2013, 06:10 AM
mark_anderson_u's Avatar
Quoted: 43 Post(s)
Liked: 42
What kind of budget do you have?
What kind of sources do you listen to?
If you listen to a lot of movies (or even TV that has 5.1), I'd definitely get 5.1 (2.1 will be way better than just 2 ch). My biggest piece of advice is don't skimp on Sub. I just upgrades to an SVS SB13-Ultra: it transformed my sound system.
You could look at a decent soundbar (if you don't have space for front speakers) and a good sub to start and then add satellites later
I'd personally steer clear of Onkyo if heat is at all an issue (i.e. it's in an enclosed space). My $2.2K Onkyo died because the cheap B&$^&*%s used 85-degree rated capacitors. What did that save them..10c?
You could look at wireless speakers to solve your issue of running wires (you obviously need power to them, but don't have to run anything to the AVR. Make sure you get WISA compliant ones (not too many on market). They will be compatible with multiple vendors' products and quality is great (technology avoids pitfalls of most other wireless designs). I interviewed the founders of WISA and listened to prototypes at a trade show (you how problematic wireless is at these). Sounded incredible and not a glitch. I wrote a short article here: http://www.hometoys.com/emagazine/2012/10/home-theater-in-a-box-redefined-by-wisa-systems/2051
Regards
Mark
mark_anderson_u is offline
post #4 of 8 Old 06-25-2013, 10:35 AM - Thread Starter
Regards
Mark
I do a lot of gaming on the PS3 & my fiancée uses the Xbox for her Kinect; we stream most movies through the AppleTV, but jump into my Blu-Ray collection on the PS3 every now and then. But I'm pretty sure all those are optimized for 5.1 output. I definitely don't want to skimp on the sub. My only concern is buying one that's so powerful that it kills the receiver. Is that even possible? I remember my friend's old shelf system dying out because the speakers were too strong.
No enclosed spaces for me and my living room is fairly cool, so I think Onkyo will be okay. Otherwise, am I good to go with Denon? My fiancée is convinced we should get this one: http://www.amazon.com/Denon-DHT-1513BA-Channel-Theater-Acoustics/dp/B007R8U5RG. It's a bit more than I wanted to spend since I wrapped my mind around staying below $500 if I bought piece by piece.
post #5 of 8 Old 06-25-2013, 11:04 AM
Quoted: 43 Post(s)
Liked: 42
Originally Posted by FamousRealName View Post
I do a lot of gaming on the PS3 & my fiancée uses the Xbox for her Kinect; we stream most movies through the AppleTV, but jump into my Blu-Ray collection on the PS3 every now and then. But I'm pretty sure all those are optimized for 5.1 output. I definitely don't want to skimp on the sub. My only concern is buying one that's so powerful that it kills the receiver. Is that even possible? I remember my friend's old shelf system dying out because the speakers were too strong. .
No such issue with the sub as it is a an active device. You are feeding a line level signal and the amp in the sub does all the work
post #6 of 8 Old 06-25-2013, 11:07 AM
Quoted: 43 Post(s)
Liked: 42
I don't know much about systems in the $500 price range, but I do keep hearing rave reviews about the Andrew Jones deigned Pioneer 5.1 system. (He designs $80K systems TAD). A friend of mine bought a Mirage OmniSat 5.1 system that isn't bad for the price, but the bass (or price smile.gif) will be nothing like the SVS stuff
post #7 of 8 Old 06-25-2013, 10:17 PM - Thread Starter
I honed in on some Pioneer Andrew Jones speakers on Amazon today, too. The FS52 and the SW8MK2. Thinking of buying those first and then building around it if I want upgrades. I'm liking what I've read of the Denon AVR 1513 but would Pioneer speakers play better with a Pioneer receiver? It's about $50 more than I wanted to spend on a receiver, but I understand that it offers a little more control over the sound.
post #8 of 8 Old 06-26-2013, 12:30 AM
tougeeco5's Avatar
tougeeco5 is offline
