Piece of carpet under sub? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-29-2013, 05:50 PM - Thread Starter
Ardothewan's Avatar
I have travertine tile floors. My sub is on spikes. I had some extra carpet laying around I was wondering if it makes sense to cut a few pieces and put it under the sub and front towers? Sub is HSU-STF1 the manual says it is intended to fire into carpet so I figured I'd put a piece under there but not sure if that makes sense if it's just a piece lol.
Ardothewan is offline
post #2 of 3 Old 06-30-2013, 06:20 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I don't know if its worth the time to cut the free carpet to size or not. Probably not.
I'll bet that if you played sine sweeps through your sub you'd find that at one or more frequencies the sub rattles around on the Travertine floor on those spikes. It might even dance!
Rubber feet from a home improvement or hardware store will address that.
There is a good chance that your room is overly reflective and needs acoustic treatment.
arnyk is offline
post #3 of 3 Old 07-01-2013, 05:15 PM - Thread Starter
Ardothewan's Avatar
Yea my ceilings are like 30 feet high too so not the ideal room but it is what it is. I cut the carpet squares wasn't really much effort. I had been using the sub with just the spikes on the tile for years though without too many problems.
