SMALL or LARGE for watching sports on 5.1? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-30-2013, 01:08 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Today i started watching some NON-HD sports / HD sports on my TV hooked up with an ONKYO receiver and 5.1 system. My fronts are JAMO S608 tower speakers , JAMO S60 center and some JAMO rear speakers along with JAMO SUBWOOFER 250.
I know my system is designed for movies but i am now using it 20% for sports too. I am watching sports using the PL 2 music mode as i can adjust the width , dimension , etc.
Should i keep the speaker settings at small with 80hz crossover as used for movies or should i set my front speaker to LARGE ? Or maybe everything to small and raise the subwoofer level ? I like the increased bass during sports. With 0dB subwoofer level from the AVR is fantastic for movie playback , but as for watching football , no bass at all.
dazkyl is offline
post #2 of 12 Old 06-30-2013, 01:28 PM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
I'd say leave the crossovers as they are and bump up the subwoofer to taste as you see fit.
primetimeguy is online now
post #3 of 12 Old 06-30-2013, 01:29 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Should i bump it from the AVR volume levels or from the knob on the back of the sub ?
dazkyl is offline
post #4 of 12 Old 06-30-2013, 02:32 PM
Quoted: 556 Post(s)
Liked: 359
AVR since that way it is much easier to get back to the original volume.
post #5 of 12 Old 06-30-2013, 02:40 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
I am curious as to why you think there might be less need for bass management with televised sports than with movies.
BIslander is offline
post #6 of 12 Old 06-30-2013, 03:22 PM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Interesting, and oddly just the opposite for me.
I bring the LF down significantly for most sports, news, etc. I utilize full bandwidth playback with well executed/well produced TV shows, dramas, action etc. And for some TV productions*, I need to boost the LF way way up to achieve decent balance.
*music acts on Tonight Show, American Idol, Grammys (for some reason ... typically most all live sound productions there's a dearth of bottom end).
Anyway, I'd not mess with the bass management/filtering settings, but that's me. I understand your conundrum, as I prefer to have LF balance handy at my finger-tips. Coming from a pro-audio FOH engineering background, old habits die hard. At my seat, I have handy level controls for all my subs, with parametric EQ and variable high-pass control all at arms length.
So, I understand your position.
That said, I'd do it however you can the easiest way to accomplish it, and most importantly, get it back to normal/calibrated point.
Best of luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #7 of 12 Old 06-30-2013, 03:25 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
What do you mean?
dazkyl is offline
post #8 of 12 Old 06-30-2013, 03:26 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
Best of luck
I think i will be bumping the subwoofer from the AVR when watching sports although basically there is no bass in sports especially football.
dazkyl is offline
post #9 of 12 Old 06-30-2013, 03:29 PM - Thread Starter
dazkyl's Avatar
Quoted: 22 Post(s)
What do you mean?
Some folk told me that i should run my fronts at LARGE setting because i will get more bass from these mains than my sub.
dazkyl is offline
post #10 of 12 Old 06-30-2013, 03:47 PM
BIslander's Avatar
Quoted: 246 Post(s)
Liked: 190
^^ That seems unlikely. But, if true, then you should run them large with everything.
post #11 of 12 Old 06-30-2013, 05:48 PM
crn3371's Avatar
Quoted: 239 Post(s)
Liked: 192
You could try running your fronts large with extra bass enabled for the sub
crn3371 is offline
post #12 of 12 Old 06-30-2013, 07:28 PM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
What do you mean?
Your sub must be a POS.
You get two benefts from using a good sub and setting your L & R speakers in Small mode:
(1) The front speakers are freed from the need to handle bass which generally makes them sound cleaner.
(2) Your subwoofer is supposed to be able to do a far better job of handling bass than your : & R speakers
I've personally experienced both of these benefits. They are dependent on correct positioning and level adjustments of all speakers and subwoofers(s) involved.
arnyk is offline
